Author Topic: '75 CB550 - HELP NEEDED  (Read 6852 times)
Offline sniper1
  • SNIPER1
« on: September 23, 2012, 06:33:49 PM »
I have been chasing gremlins on '75 550. Here is the problem:
I recently rebuilt this bike, just finished (or so I thought...) two weeks ago. Bike ran good for about a week or so. Last weekend it started having issues.
It seems to run fine when cold. When it warms up a bit (after about 5-10 minutes of riding) it suddenly starts to bog down. It feels like its starving for fuel. It won't go over 4000 rpm or 40 mph. The tone of muffler is really low and "bassy." Sometimes it will surge forward like its getting gas again, but quickly bogs down again. Today, I checked valve clearance again (.05 intake, .08 exhaust) all good. Made sure cam chain adjustment done, good. rechecked timing and breaker point gap, all good. I only checked 1 and 4 spark plugs, they were a little black, nothing major, so a little rich, maybe. I didn't pull 2 or 3.
I did recently rebuild the carbs with all new inards: 100 mains, 38 slow, air mixture screw out 1 turn. Bench Synched them and then vaccum synched. It ran good for about a week after doing this. Now all this.
Bike has 12k miles on it. 4-1 MAC exhaust, stock airbox w/new filter, everything else stock.
WHAT COULD POSSIBLY BE THE PROBLEM??
Fuel?
Electrical?
Spark?
Air?
Soichiro's curse???
WTF??
Offline Mo
Re: '75 CB550 - HELP NEEDED
« Reply #1 on: September 23, 2012, 07:29:46 PM »
hmm. Could be out of sync carbs. The fact that you have new jets installed hints at that. Have you tried to re-sync them?
Offline luap
  • LAWL
« Reply #2 on: September 23, 2012, 07:54:10 PM »
.05 an .08 isnt stock but I think hondaman recommend that. .02 an .03 is stock from book
Fuel? wheres your needle clip?"It feels like its starving for fuel" you set the floats correct 22mm
Electrical?have you tested battery?
Spark? pull the plugs an rest them on the head
Air?so a little rich", maybe- not enough air. you turn your air screw out more
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: September 24, 2012, 01:12:06 AM »
You could try releasing the cap on the gas tank, if it's not venting properly it will hold the fuel back due to low pressure in the tank. I say low pressure because vacuum seems too strong a word.
Of course don't forget that the nylon sock on the petcock might be gunked up after all these years with such low mileage as well.
Turn the petcock off, place a container below the outlet, turn the fuel on & see what sort of flow is there perhaps.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline mronegear
  • Honda CB 550 F 1976
« Reply #4 on: September 24, 2012, 01:19:46 AM »
sounds like a fuel problem to me.
How is the inside of your tank? clogged petcock or breating vent?
Do you run the bike with inline filters?
Does the bike rev over the 4000 when its not boggin down? If no its set up way to rich,
turn the air-mixture screws out more (max. 2 turns) Where is your neddle cliip position at?
nedds to be at 2nd grove from top at the f model and 4th groove from top at the k model.
Does it run on all 4 cylinders? check temp of the headers.
good luck!
Offline sniper1
  • SNIPER1
Re: '75 CB550 - HELP NEEDED (Now with plug pics)
« Reply #5 on: September 24, 2012, 05:45:03 PM »
OK, I got around to pulling the plugs. Here are some pics. Its 1,2,3,4 from right to left in both pics.
One thing I did notice was that I only had the air mixture screw out on the carbs 3/4 turn. I was playing around with it and thought it seemed to run better like that than 1 1/2 turns out. Maybe I was wrong.
Could that have caused the rich mixture and bogging/surging issues?
Can I still use these plugs? or should I replace?
Offline luap
  • LAWL
« Reply #6 on: September 24, 2012, 06:27:02 PM »
Could clean those plugs ride it see where you at an when your good put new plugs in
www.cb-town.com
Offline luap
  • LAWL
« Reply #7 on: September 24, 2012, 06:29:35 PM »
MRRON
where did you get that info from?
www.cb-town.com
Offline DJ_AX
« Reply #8 on: September 24, 2012, 06:48:51 PM »
yes .... could have
Offline Killer Canary
  • Typical Bran Muffin
« Reply #9 on: September 24, 2012, 06:53:23 PM »
Did you determine which cylinder(s) isn't functioning? that would tell us a lot.
Kawi GPz900, H1
Offline LesterPiglet
  • 1977 CB550F2
« Reply #10 on: September 24, 2012, 07:03:13 PM »
My plugs are like that after idling if not sootier. Clean them and reuse. I don't understand people throwing away perfectly usable plugs. I shouldn't think your engine will run properly with the air screws turned in that much. 1.5 turns give or take should be close.
Offline sniper1
  • SNIPER1
« Reply #11 on: September 24, 2012, 07:06:30 PM »
I haven't yet. I will clean these plugs, back out the air mixture screw again and see what happens.
I really don't want to have to pull the carbs and take them apart again if I don't have to.
Offline sniper1
  • SNIPER1
« Reply #12 on: September 24, 2012, 07:08:17 PM »
Ok, thanks. I'll give it a shot.
« Reply #13 on: September 24, 2012, 07:36:50 PM »
that pic with the plugs in your hand?...are they displayed in order l to r  cylinders 1, 2, 3, 4?,...if so, 1 and 4 look alright, 2 and 3 look bad...I'd be lookin' at your ignition system...
Offline sniper1
  • SNIPER1
« Reply #14 on: September 24, 2012, 07:48:30 PM »
Anything in particular? I did check timing and made sure it was correct. Points were gapped correctly and timing was right.
« Reply #15 on: September 24, 2012, 08:00:43 PM »
Are you sure that all four cylinders are even firing?  I've seen when sparkplugs get that sooted up, the spark don't jump at the electrode, it will go somewhere else...so even if you got spark, it won't fire the cylinder.  I'd start by checking for 12 volts at the coil, maybe a dirty black/w white stripe connector for the 2/3 coil?  Check coil primary and secondary resistance, spark plug cap resistance?  Two Tired has excellent instructions for this in the FAQ.
  • 1977 CB550F2
« Reply #16 on: September 25, 2012, 02:21:16 AM »
If they weren't sparking they would be wet not sooty tho looking again I do see a bit of a shine off them.
Offline sniper1
  • SNIPER1
« Reply #17 on: September 25, 2012, 04:25:48 AM »
The plugs arent wet. They are just sooty.
  • 1977 CB550F2
« Reply #18 on: September 25, 2012, 06:42:32 AM »
In that case my four plugs are like your 2 and 3.
Offline mronegear
« Reply #19 on: September 25, 2012, 06:53:52 AM »
MRRON
2nd from Top is stock for the Supersport and 4th from Top is stock for the k Models. My manual tells
me that and i'm pretty sure that is correct.
Offline sniper1
  • SNIPER1
« Reply #20 on: September 25, 2012, 04:23:57 PM »
OK, I installed new spark plugs and fired it up. It does not appear to be firing on cylinders #2 and #3. When it started it was running very rough, had a very low tone, and when I felt the header pipes, #1 and #4 were hot, but #2 and #3 were cold.
Any thoughts on where to start checking. I am now thinking electrical. The points are gapped correctly, and I used a static method to set/check ignition timing. That went good for both 1 & 4, and 2 & 3. Plugs are new and gapped correctly. Tappet valves good.
What else could it be??
- ignition coil?
- plug wires?
- condensor?
- points?
- anything else?
This phenomenon came on relatively slowly but now seems permanant. What would cause this?
ANY HELP IS GREATLY APPRECIATED!!
Offline luap
  • LAWL
« Reply #21 on: September 25, 2012, 04:28:37 PM »
pull 2 plug out an lay it on the head kick it over look for spark
check the blk/wht wire off coils make sure getting a soilid connection from power
www.cb-town.com
Offline windwalker
« Reply #22 on: September 25, 2012, 05:11:26 PM »
methanol is playing havoc with our motorcycles. if you have fuel filters remove them. the alcohol is dissolving the glues that hold them together or fuel tank liner gelling? good luck
Offline sniper1
  • SNIPER1
« Reply #23 on: September 25, 2012, 05:42:29 PM »
The only fuel filter is the sleeve on the petcock. I agree, stupid ethanol. Politicians are not only screwing up the whole country,,,,,they're screwing up our bikes!!!!
Offline sniper1
  • SNIPER1
« Reply #24 on: September 25, 2012, 05:44:44 PM »
Is there any way of testing by putting #1 and #4 wires on #2 & #3 to see if they go. I think the timing would be off, but would it work just to see if they fire?
