Author Topic: '75 CB550 - HELP NEEDED  (Read 6880 times)
Offline sniper1
  • SNIPER1
Re: '75 CB550 - HELP NEEDED
« Reply #25 on: September 25, 2012, 06:07:41 PM »
I just pulled the #2 plug, wired it up and fired the engine. No spark whatsoever. Now what????
Is it possible that the condensor is bad?
Could it be bad ignition coil?
Tank rubbing against wiring harness causing problems?
Where should I start to check? and how?
« Reply #26 on: September 25, 2012, 06:15:47 PM »
Plugs sooting up are almost certainly the air screws in too far.  Especially if you have the 069a carb with the solid tipped needle.
I don't care if you have and F model, unless you have the stock 4 into one muffler, you should have the carbs set up like a K model for the same year.  Replacement mufflers wer expected to replace the 4 into 4.
What is the condition of the condensers?  If you you swap them from side to side does the spark problem follow them?
I still don't get why you would adjust the tappets to anything besides Honda factory spec.  All mine have run well with those settings.  Maybe if you are racing or have a special cam, the clearance should be different.  But, Honda knew how to build a pretty stout engine.  But, if you must experiment, good luck!
Offline sniper1
  • SNIPER1
« Reply #27 on: September 25, 2012, 06:35:58 PM »
That's a good idea, i will try that and see what happens.
I did adjust to factory settings. Everything according to the three different manuals I have.
Offline luap
  • LAWL
« Reply #28 on: September 25, 2012, 06:46:15 PM »
Is it possible that the condensor is bad? swap 1-4 point condensor to 2-3 points see if that works
Could it be bad ignition coil? do a search to see how to test coils, http://forums.sohc4.net/index.php?topic=5752.msg8383#msg8383
Tank rubbing against wiring harness causing problems? do you have worn wires, an why is the tank rubbing
Where should I start to check? and how? get tank off of harness.
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline Bailgang
  • Scott
  • Indiana
« Reply #29 on: September 26, 2012, 02:01:17 AM »
I'm the one that gave him the idea of the tank/harness issue. I just purchased a seat from him so we were PMing back and forth about this subject last night. I had issues with one of my coils on my 550 getting knocked out and running on only 2 cyls and I knew it had to do with the tank because it would always do it after I'd pull the tank and put it back on. Not sure how it was doing it because none of the wires were bare and all the connections for the coils were shielded/insulated but none the less that clump of connectors was getting pinched by the tank some how. I ended up make sure all connections were clean and made sure they stayed away from the tank and the problem went away. It's a long shot as to whether that's the problem sniper is having but it's worth looking into because many of the issues I had with my 550 when I first got it running ended up being simple stuff that I had assumed was OK and didn't dbl check.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
