Author Topic: I need all of your help on this!!  (Read 3381 times)
Offline Trevdawg
« on: September 29, 2012, 03:52:25 PM »
So I came across this in the woods. Weeds growing over it. So I thought it had potential.
I know it is a dual over head cam. But until I move over to that sight I am looking for your help. Especially since I worked on a single over head came already.
It has no cars, no tank, no seat, no side covers!!!!! And I can only assume what else.
I sprayed P.B. blaster over the plugs and in the chamber. Let it sit for a bit. I just want to get this to rotate.
So the oil is black, but not empty.
I am new to working on bikes and would like any advice/ help you have to get this thin to rotate. Let me know. ...
Offline Trevdawg
« Reply #1 on: September 29, 2012, 03:53:08 PM »
It has 17,000 miles on it too...
Offline LesterPiglet
  • 1977 CB550F2
Re: I need all of your help on this!!
« Reply #2 on: September 29, 2012, 04:00:33 PM »
That's a SOHC 550K.
« Reply #3 on: September 29, 2012, 04:11:15 PM »
That's a SOHC 550K.
+1. Didnt you read the VIN plate?  Where do you see "dual" cams??
Offline toytuff
  • "watching the pinheads"
« Reply #4 on: September 29, 2012, 04:13:20 PM »
Send me the motor! I'm looking for one.  ;)
tt
Offline Trevdawg
« Reply #5 on: September 29, 2012, 05:04:48 PM »
Well I guessed it was a dual over head cam cause there is no spot for the oil tank. To check the oil is from the crankcase.
On the 74 I had you would have to checked it from the oil tank. On this one you can see the battery sits more off to the side where the oil tank would have been. In comparison to the 74 I had where the battery sat directly behind the carbs, between the oil tank and electronics.
  • 1977 CB550F2
« Reply #6 on: September 29, 2012, 05:06:58 PM »
The 750 is dry sump, the rest of the fours are wet sump= no oil tank.
Instead of spraying your PB, fill the cylinders. If you do a search of the forum you will find some concoctions other members have used.
« Last Edit: September 29, 2012, 05:09:16 PM by LesterPiglet »
Offline Trevdawg
« Reply #7 on: September 29, 2012, 05:07:38 PM »
Offline toytuff
« Reply #8 on: September 29, 2012, 05:08:55 PM »
Send me the motor!
 ;D
tt
« Reply #9 on: September 29, 2012, 05:16:33 PM »
Send Toy the motor!
  • 1977 CB550F2
« Reply #10 on: September 29, 2012, 05:18:13 PM »
He won't have any use for a speedo then. Send that to me.   ;D
« Reply #11 on: September 29, 2012, 05:19:58 PM »
For some reason, those '76 light green guages seem to stay in good shape.
Offline Trevdawg
« Reply #12 on: September 29, 2012, 05:23:34 PM »
The front is good. You should see how the housing/ back of them are rusted.
Was green a common color on the gauges??
  • 1977 CB550F2
« Reply #13 on: September 29, 2012, 05:27:28 PM »
I may be wrong but I think only the 77 F's were blue. If you mean the chrome backs that doesn't matter, I have new ones.  :)
« Reply #14 on: September 29, 2012, 05:27:36 PM »
'76 & 77[?]
Offline Trevdawg
« Reply #15 on: September 29, 2012, 05:46:47 PM »
Well the 74 - 750 I had, had green gauges too. But then it had the green panels, tank also.
Offline Trevdawg
« Reply #16 on: September 29, 2012, 05:49:34 PM »
That's a SOHC 550K.
Frame vin is different than motor.
Frame-
Motor-
Offline Trevdawg
« Reply #17 on: September 29, 2012, 05:57:35 PM »
What is the best phrase to use on the search, etc.?
Offline toytuff
« Reply #18 on: September 29, 2012, 06:00:20 PM »
Blue was used on the instruments in 1977 on both the K and F.
tt
« Last Edit: September 29, 2012, 06:07:57 PM by toytuff »
  • 1977 CB550F2
« Reply #19 on: September 29, 2012, 06:01:07 PM »
Stuck motor?
Offline Gordon
  • 750K1, 550K2
« Reply #20 on: September 29, 2012, 06:01:14 PM »
That's a SOHC 550K.
The frame and motor numbers will always be different.
« Reply #21 on: September 29, 2012, 06:03:36 PM »
Frame & engine #'s rarely, if ever, match.
Do you have title? If no, your best bet would be to part it out. Prolly cost $2K to get roadworthy.
Offline Trevdawg
« Reply #22 on: September 29, 2012, 07:21:48 PM »
No title.
Was considering a long term project.
Offline Trevdawg
« Reply #23 on: September 29, 2012, 07:22:45 PM »
Stuck motor?
Of course. That's why I was looking for a way to free it up on here
Offline luap
  • LAWL
« Reply #24 on: September 29, 2012, 08:40:10 PM »
what are you going to do with the pipes?
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
