Author Topic: 1977 Honda 750 Supersport First Gear  (Read 1197 times)
Offline reliv77
« on: September 30, 2012, 04:31:59 AM »
I took the Bike out for a longish ride yesterday. The longer I rode, dropping into First Gear, got more difficult. When it did go into Gear, it really seemed to "Bang" into First Gear. Then a little difficult going into Neutral. Any Thoughts? Can the Transmission Fluid be low?
Offline MoMo
  • Ride like you're invisible
Re: 1977 Honda 750 Supersport First Gear
« Reply #1 on: September 30, 2012, 04:37:31 AM »
Is this a new problem or is the bike new to you?  Clutch properly adjusted?  I had a similar problem on a 750 I purchased-in my case the motor case was starting to break at the sprocket area :'( :'(...Larry
« Reply #2 on: September 30, 2012, 04:41:11 AM »
There is no seperate transmission oil per say it all is lubed with your engine oil.Some people complain of poor shifting when the oil starts getting old and broke down,have you changed your lately ? Other than that maybe the clutch needs some adjustment.
Offline reliv77
« Reply #3 on: September 30, 2012, 04:55:51 AM »
This is a New Bike to me. Just got it about a week ago. I was told the Oil was changed. On the Dip Stick it looks clean. If the Clutch needs adjusting, how do I go about it?
« Reply #4 on: September 30, 2012, 05:32:10 AM »
Download or get a manual and start reading up to learn your machine is the best start. Probably some threads around here on the search function.
  One other thing also if new to you may be technique related also,getting used to the bike. I have a couple of examples that are 'happier' going into neutral when I snick it in there just as it is rolling to a stop.
« Last Edit: September 30, 2012, 05:49:58 AM by ekpent »
Offline reliv77
« Reply #5 on: September 30, 2012, 05:48:45 AM »
Can anyone Link me to a Manual?
« Reply #6 on: September 30, 2012, 05:51:35 AM »
Offline reliv77
« Reply #7 on: September 30, 2012, 06:46:26 AM »
Tried to Down Load the "Honda CB750 Four CB 750 Workshop Service" but it Downloads with an Error. Can Anyone give me an idea how to adjust the Clutch.
Offline LesterPiglet
  • 1977 CB550F2
Offline reliv77
« Reply #9 on: September 30, 2012, 06:58:49 AM »
Tried again but the PDF Dowloads all scrambled.
  • 1977 CB550F2
« Reply #10 on: September 30, 2012, 07:32:53 AM »
Something wrong with your puter? I've just had a quick look at some pages from it.
Offline reliv77
« Reply #11 on: September 30, 2012, 07:45:23 AM »
On a Mac. Downloads most everything. Anyway to send me the page on Clutch Adjustment.
My email: geraldgabor@att.net
Thanks.
Offline CycleRanger
  • No comment about being an
« Reply #12 on: September 30, 2012, 09:06:22 PM »
Good pdf's of the shop manual & parts list here.
http://www.honda4fun.com/materiale-documentazione-tecnica/shop-manual
