Author Topic: Saw a couple 750 Fs last night (pic)  (Read 1724 times)
Offline mono
  • Definitely no
« on: September 30, 2012, 10:41:42 AM »
A sohc and a dohc.  Pic kinda sucks, but they were purty.
Sent from my SPH-L710 using Tapatalk 2
Offline lostmykeys
Re: Saw a couple 750 Fs last night (pic)
« Reply #1 on: September 30, 2012, 09:08:56 PM »
 You should ride an F...they handle like a dream.
 These bikes were at the time, beyond the limits of most riders and still are.
 These bikes are not your grandpas K, If you just want to cruise around,then K's are cool but if you have the skills and  want to ride a vintage bike from the Honda SOHC era...get the F!
Offline James T Kirk
    • Moabite
« Reply #2 on: September 30, 2012, 10:39:42 PM »
the pods on that DOHC will make it run like #$%*.
looks cool though.
kirk out
« Reply #3 on: September 30, 2012, 10:45:16 PM »
Not hard to make a K handle mate, use to embarrass a few big Kawasaki's back in the day....
Offline lostmykeys
« Reply #4 on: September 30, 2012, 10:54:42 PM »
 Retro,good point but the F in stock form will allways out handle a K.
 The F or the K in stock form will never out accelerate a Z-900.
« Reply #5 on: September 30, 2012, 11:15:57 PM »
Yes, a stock 750 will never out accelerate a 900 but they handle better and corners are where its at.... As for the F and K bikes, its more up to the rider than the bike, both were pretty good handling bikes in the right hands, they both had the same limitations...
Offline mono
  • Definitely no
« Reply #6 on: October 01, 2012, 08:48:15 AM »
trust me, i tried!  but none of my keys worked....  !!!   ::) ::)  haha just kidding.  actually, the guy on the DOHC came out and i annoyed him with questions and compliments for a few minutes.  however, judging from his responses, i don't think he actually did any of the work himself.
it seemed to run OK when he fired it up, though - although he was winding it up pretty high.  i notice a lot of people say that the DOHCs suck with pods on them (at least, everyone on the DOHC forum does) -- kind of worries me since i would *like* to run pods on my DOHC 750 that i'm working on now.  i have read that putting restrictors on the pods will help with that.  anyone have any experience?   if so, please PM or post in my DOHC thread (linked in my sig) :)
Offline Killer Canary
  • Typical Bran Muffin
« Reply #7 on: October 01, 2012, 09:00:22 AM »
I can't see how there were enough differences between sohc fs and ks to be that noticeable. same frame, minor engine changes, the Fs carried a fair amount of extra weight. The braking should have been better due to the extra discs. I've always seen it as a styling exercise. If I'm off the mark I don't mind being told though :)
Kawi GPz900, H1
Offline mono
  • Definitely no
« Reply #8 on: October 01, 2012, 09:09:43 AM »
(moves to higher ground in preparation for the flood)
« Reply #9 on: October 01, 2012, 09:17:35 AM »
Nyuck x 3 ;D
Kawi GPz900, H1
    • Moabite
« Reply #10 on: October 01, 2012, 09:32:46 AM »
Stock carbs on these engines are CV sliders which means if there is not enough vacuum from the airbox, the sliders wont work! They're heavy sliders. Keep the stock airbox and paper filter for best operation with CV carbs.
K&N CAN be used if you like having a reusable filter, but the airflow offset does cause flat spots around 5000-6000 rpm which sucks cause thats usualy highway cruising speed.
Air box and paper filter is the only way to go unless you have unlimited resources with a dyno and time to burn pulling and rejetting and pulling and rejetting until you almost have it right but, you will never ever improve on these carbs. All you will do is make them work almost as good as they did when they were stock.
kirk out
Offline mono
  • Definitely no
« Reply #11 on: October 01, 2012, 01:59:31 PM »
[in my best Nimoy voice]
thank you, captain.  this is most logical.
--- seriously, that's a bummer, though.  now all of the hipsters will make fun of me.  :(
« Last Edit: October 01, 2012, 02:01:39 PM by mono »
Online seanbarney41
« Reply #12 on: October 01, 2012, 03:13:31 PM »
+1...actually, the f has a longer swingarm and more rake/trail (I think)...which would make it turn slower, ...probably more stable though
Offline BeSeeingYou
« Reply #13 on: October 01, 2012, 10:47:29 PM »
Trail is 3.7 inches for the K and 4.5 for the F and the rake is 27 and 28 degrees......a noticeable difference in stability.  Overall the F is a better handling bike.  The F0/1 is 20 lbs heavier....not sure where it all comes from but most may be from the rear disc...it's down low so not that big a deal to me.
« Reply #14 on: October 06, 2012, 08:49:24 PM »
I currently own both, a 76F and 70K. To me the F feels like a larger bike, after riding it my K0 feels like a 450. The K turns in quicker and feels lighter even though the weight  isn't much different. My F does have triple discs.
Offline ofreen
« Reply #15 on: October 06, 2012, 10:40:38 PM »
All that awesomesness does carry a small weight penalty.
Greg
'75 CB750F
Offline Magpie
« Reply #16 on: October 07, 2012, 10:04:52 AM »
My 1980 750F is a much larger bike than my K1's. The distance to the handle bars on the DOHC is larger but the distance from the seat to the footpegs seems less than the SOHC's. My hips give me trouble now riding the DOHC F. Old age creeping in I guess plus long legs (34"). The F seems to flop into the corners a bit and needs more countersteering than my K's too. However I enjoy riding both all of them! Cliff.
Offline mono
  • Definitely no
« Reply #17 on: October 08, 2012, 12:16:24 PM »
Magpie - i'd be happy to adopt your F if you can't take it for walks anymore.... ;)
Offline Magpie
« Reply #18 on: October 08, 2012, 03:00:46 PM »
thanks mono, I'll keep that in mind.  :D Cliff
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #19 on: October 08, 2012, 03:26:40 PM »
Ha!!  ;D
