Author Topic: fork filler cap  (Read 1567 times)
Offline wardenerd
  • '77 550F '81 650C
fork filler cap
« on: October 13, 2012, 07:25:49 PM »
Are the fork filler caps on my 1977 550F under pressure I want to pull them for polishing.
Offline goldarrow
  • one day, i'll be an
Re: fork filler cap
« Reply #1 on: October 13, 2012, 07:35:00 PM »
Fork spring is in the fork, so spring load is there.  But you should be able to just loosen it using wrench, then turn it using hand, push it down as you turn it. Go slow and be careful as it will fly off and might hit your face.
CB550 K0
Offline Gordon
  • 750K1, 550K2
Re: fork filler cap
« Reply #2 on: October 13, 2012, 07:52:11 PM »
Jack up or otherwise support the front end to take the pressure off the springs.  It won't make a big difference for removing the caps, but will make installing them much easier.  If you don't support the front, only remove one cap at a time or your bike will fall on its face.
