Author Topic: 1977 Honda 750 Supersport Chain Lube  (Read 1620 times)
Offline reliv77
« on: October 14, 2012, 08:25:44 AM »
Can anyone recommend a Good Chain Lube for my 1977 Honda 750 Supersport. Would WD40 be OK?
Offline Deltarider
Re: 1977 Honda 750 Supersport Chain Lube
« Reply #1 on: October 14, 2012, 08:37:42 AM »
WD40 is fine to clean. Not as lube. Have you done a search?
CB500K2-ED Excel black
Offline reliv77
« Reply #2 on: October 14, 2012, 08:45:23 AM »
Searching but not finding.
Offline Deltarider
« Reply #4 on: October 14, 2012, 09:30:25 AM »
PJ1 makes a good product.
Your bike originally came with a 630 Oring chain.  I don't think I'd want to use WD40 (mostly solvent) on the orings.  But, WD40 is pretty thin as applied, to prevent lots of fly off, you apply it to a hot chain and let sit overnight, allowing the solvent to evaporate, and leave a thin oil film behind.
PJ1 Blue chain wax works well for oring chains.  Again, applied to a hot chain and allowed to dry overnight, it virtually eliminates fly off and needed wheel cleaning later.  If your present chain is dirty, Blue label won't clean it for you, that will be a separate operation.  But, blue label will help keep the chain clean on new or cleaned chains.
Here's their rather infantile web site, for a pretty decent product.  If you like video action games, you'll probably like  the distraction effects.  ;D
http://www.pj1.com/
If your bike has had a chain conversion to standard, then PJ1 black label is what I have been using for many years.
Offline ofreen
« Reply #5 on: October 14, 2012, 09:28:14 PM »
Here's a link to an old thread where I detailed my experiment using WD40 on an o-ring chain and new sprocket set spanning 3 years and 16,000 miles.
http://forums.sohc4.net/index.php?topic=4621.0
Greg
'75 CB750F
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #6 on: October 15, 2012, 09:24:21 AM »
FWIW, Maxima Chain Wax is good too.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline Jiminy Indy
« Reply #7 on: October 15, 2012, 12:25:07 PM »
Yep, make sure you get all the gunk off your chain first - I just use standard car wash. It cuts the grease pretty well.
And the chain wax stuff i really like. Not as messy as the lubes, keeps my chain cleaner. Not sure about long term wear as opposed to chain lube, but so far so good...
Of all the things I've lost, I miss my mind the most.
"Shot up the alley and then cut across the street" - now that's some violence you can appreciate!
