Author Topic: Listen to my engine, what would you do/start with ?  (Read 5359 times)
Offline Viktor.J
  • Breaking in the forum
« on: October 25, 2012, 04:04:31 AM »
Hi !
I bought this bike a couple of months ago and since I didn't take the driver license or have a garage near, i haven't had much time tuning it.
But now the winter is approaching and i will have plenty of time..
Can you guys please listen to the motor, how does it sound and what would you check first ?
IMO it doesn't sound that good, so hit me :)
MVI 3704
(There are more videos on my youtube account)
My plan is to tear down the carbs, clean them up and then properly tuned
Tension the cam chain
Trying to check the timing ?
So tell me, what would you do and where would you START !
Kindly regards
Viktor.J
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline cb650
Re: Listen to my engine, what would you do/start with ?
« Reply #1 on: October 25, 2012, 04:33:06 AM »
Thats what a 650 sounds like when the cam chain tensioner is in wrong.   Many of them on utube too.
Offline Viktor.J
« Reply #2 on: October 25, 2012, 04:35:57 AM »
Thats why I want "real" input. Just beacuse i find a video on the tube of a bike with a "bad cam tension" -headline doesn't have to mean thats the problem.
I've also found "bad synced" carbs videos who also sounds like this.. thats why my questions, and what to start with ? I guess, the carbs last ?
BTW its a CB750 K2
Honda CB750 K2
Offline Xnavylfr
« Reply #3 on: October 25, 2012, 04:54:49 AM »
To start with do you have a manual????
Do what they cal a 3000 mile tune up (I don't know how many Km that would equal)
Oil/Filter change
Set Timing
Adjust valve tappets
Adjust cam chain
A varied list of general maintenance items to be accomplished!!
 The noise on your bike does sound like cam chain and it's very easy to adjust.
Xnavylfr(CHUCK)
Offline Viktor.J
« Reply #4 on: October 25, 2012, 05:08:21 AM »
Oil/Filter change
Set Timing
Adjust cam chain
Xnavylfr(CHUCK)
I Have the "owner workshops" manual, clymer or something like that ( I don't have the book here now), I hope that will do good ???
But as you said, a big service would probably do good. It runs good and smooth now, but I wannted to make sure  that the noise wouldn't make any major damage !
Honda CB750 K2
« Reply #5 on: October 25, 2012, 09:45:06 AM »
Dont forget new plugs(gapped) and a good, clean air filter.
check your plug caps for resistance, or just get new caps.
Cut back the wires +/- .5cm so good wire is showing.
Carb sync comes last, only after you've done the items listed by Xnavylfr.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: October 25, 2012, 02:30:45 PM »
Carbs need synced. Primary chain is slapping.
Offline cb650
« Reply #7 on: October 25, 2012, 02:36:19 PM »
BTW its a CB750 K2
OK sorry I didnt have any "real" input.   Yes plenty on utube but I have repaired a few with this problem.  Sorry again wont bother you with my drivel anymore.     ;D
Offline Viktor.J
« Reply #8 on: October 26, 2012, 12:35:15 AM »
BTW its a CB750 K2
What i ment is thats why i asked you guys here. Because YOU have "real" more valid input rather then a youtube video filming i dont know what. For all that mathers I could drive around with a flat tire and list it as "un synched" carbs, and if someone is dumb enough...... thats what he thinks causes the problem... :)
Honda CB750 K2
Offline Viktor.J
« Reply #9 on: October 26, 2012, 12:36:09 AM »
All 4 plugs are new, air filter is clean :)
Honda CB750 K2
« Reply #10 on: October 26, 2012, 01:15:53 AM »
im with lester,you havent had the bike long and any guy could have been making any "adjustments"its already been posted to go over the scheduled service items,,be sure the ignition is as new then have those carbs synced,im sure itll mostly go away,,these bikes wernt exactly quite when new either but quieter than older english rattlers,,the quality of audio on any of these sound posts always makes things sound worse anyway?
Offline Viktor.J
« Reply #11 on: October 26, 2012, 01:26:38 AM »
Yeah im going to go over the service schedule and hopfully most of the sound dissapers !
Im aware of that they were quite loud but this sounds "to loud", like draining the exhoust sound :)
Thanks for the input guys !
Honda CB750 K2
« Reply #12 on: October 26, 2012, 01:31:05 AM »
if you havent really run it long enough to get fully hot and ridden it that might also be an issue?if your only starting it up and sort of getting it warm and letting it idle that might just be your problem?have you ridden the bike yet?even ones that are in good condition and tuned and set correctly sound better at idle once they have actually been ridden quite some while and fully hot,if youve never had a car without fuel injection and never had to "feather"the throttle on a cold engine that has a manual choke to start it i must remind you these wont just start up and idle anywhere near like you might be used to?you have good english by the way!
« Last Edit: October 26, 2012, 01:35:07 AM by dave500 »
Offline Viktor.J
« Reply #13 on: October 26, 2012, 01:37:58 AM »
I've ridden it for about 40-50 Km around 80 km/h hopfully it was warm after that :D same noise even if it was a little bit more silent.
Honda CB750 K2
« Reply #14 on: October 26, 2012, 01:43:44 AM »
oh ok,,that should be warm/hot enough then.
« Reply #15 on: October 26, 2012, 05:36:56 AM »
what you drinking ken?i want some,,looks like our swedish friend has a good old 750 four my boy?
bollingball
« Reply #16 on: October 26, 2012, 06:02:53 AM »
This threw me off Dave Just coffee maybe time to change ;D I will delete and start over sorry Victor
BTW its a CB750 K2   I should have read this.
Now where did I put that JB 9am :o
« Reply #17 on: October 26, 2012, 06:06:30 AM »
im with you ken,,,im on the couch tonite!,my wife works mornings.
bollingball
« Reply #18 on: October 26, 2012, 06:50:38 AM »
It is 9:48 am here in NC. What time is it over there? Hell What day is it?
Ken
Offline Viktor.J
« Reply #19 on: October 26, 2012, 08:49:41 AM »
Im sorry guys I'm not following... I do speak english, but I'm not that good at "slang" that i can understand  hidden messages. So, if you want to tell me something, do so :)
If not, write so we all can laugh...
Honda CB750 K2
bollingball
« Reply #20 on: October 26, 2012, 11:23:54 AM »
I'm Sorry Victor I thought you had a 650 and Dave was letting me know that you have a 750. He was joking with me and thought I had a nip into the Jim Beam Bourbon.
 But on to your bike do a full 3K tuneup and even though your air filter looks good it may be old and they break down inside and do not work as well. Make sure you do the tuneup in the correct order this is very important. Most of the time that noise is either the cam chain out of adjustment or the carbs out of sync  both of which are taken care of with a full or major tuneup. There is a lot to a good tuneup and the first one really needs to be thorough. Post back if you need any help.
Ken
« Last Edit: October 26, 2012, 11:26:07 AM by bollingball »
Offline Viktor.J
« Reply #21 on: October 26, 2012, 12:23:29 PM »
Ken
Thanks for the input. I have the clymer and I have the "Owner manual" from the forum. In the owners manual It's a section called "engine tune up" and a section called "periodical maintenance" is one of these this "3 k service" ?
I'm keen on getting it right from the first time :D
Honda CB750 K2
Offline Xnavylfr
« Reply #22 on: October 27, 2012, 05:07:00 PM »
Since you just purchased this bike you  may not know the weight or thickness of the oil!! Here in the STATES  we mostly use 30 wt. a good general range oil. Here we can also buy MULTI-WT.    This may get too confusing. Change the oil when you do the 3000 mile service. AND FILTER.
Xnavylfr(CHUCK)
Offline Viktor.J
« Reply #23 on: October 28, 2012, 01:49:42 AM »
Since winter is approaching in Sweden the bike is in the garage. And I've read some post about changing the oil after a cold 5 months stop. So I figured I change the oil next spring for next season.
I've been searching the forum but can't find any info, i guess i know basically what to do. But would love to know in what sequence to do everything, and i don't want to miss out anything, But is there any special part of a book, special schedule where I can find what to do and in what order..
I might seem quite stupid with all my questions but Id like to believe I'm not :)
It's just that its my first bike and I don't really have any to give me a first hand tutorial :)
Better safe then sorry you know.
As a mentioned I have the clymer and the 270 page owners manual ..
Thans for the input Xnavylfr !
« Last Edit: October 28, 2012, 01:56:28 AM by Viktor.J »
Honda CB750 K2
Offline City Boy
« Reply #24 on: October 28, 2012, 06:16:25 AM »
Hi Viktor.What i am hearing is a loose cam chain and noisy primary chain likely caused by out of sync carburators.At the least do a full tuneup and oil change and if you plan to do any work yourself get a shop manual and preferably a genuine Honda version.    Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
