Author Topic: What tire and tire size for a 78 CB750A?  (Read 6609 times)
Offline limerence
« on: October 25, 2012, 03:10:48 PM »
Hi guys,
Not sure if my IQ is too low but does the search option on this site work?
Anyhow, I was trying to find out what tires and tire size to get for a 1978 CB750A
From the factory service manual, looks like the size (and I believe it might be for all three years since theres no delineation amongst years) is:
Front: 3.5H19
Rear: 4.5H17A
Equating that to modern sizes, I was thinking about getting:
Front: 100/90-19
Rear: 120/90-17
But the matching name brand tire options are pretty much non existent. What is everyone running on their bike?
Thanks,
John
Offline limerence
Re: What tire and tire size for a 78 CB750A?
« Reply #1 on: October 28, 2012, 01:06:56 PM »
17 views and no response? no one else own one?
Offline salukispeed
« Reply #2 on: October 30, 2012, 09:19:07 AM »
I forget what is on my 77 but will look this evening and reply (hopefully tomorrow)
1974 CB750 K4
1970 CT70
1966 CA77 (305 Dream)
1984 GL1200 Interstate
1977 750A
1972 CL100
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #3 on: October 30, 2012, 06:44:09 PM »
You may have more luck asking this question over in the non-A forum.
The rear swingarm for the 77/78 A bikes is the same as the 77/78 K bikes.
The bikes also had the same 4.50 17" rear tire, too.
Probably a LOT more folks over in the non-A forum that will chime in.
I'd chime in - but I'm running a NOS 4.50 17 tire I bought two years ago.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline limerence
« Reply #4 on: October 30, 2012, 09:42:14 PM »
Thanks guys. I did end up looking on the non-A forum
After searching on multiple resellers... I was able to find two matching sets in 100/90-19 and 120/90-17.
- Michelin Anakee 2 Adventure
- Bridgestone BT45V
Any experience with these?
However, if I bump the rear up one size to 130/90-17, opens it up to a couple more brands like Shinko 230's that are a little more cost effective. 130's too wide?
Will look in the non-A forum too but too lazy right now to do a search. Lol.
Thanks,
John
Offline dave the welder
  • dave the welder
« Reply #5 on: October 31, 2012, 05:21:14 PM »
i am running a 130.i have no clearance problems at all. on the side wall it says its the same as a 5.10 if that helps
« Last Edit: October 31, 2012, 05:23:29 PM by dave the welder »
don't buy it build it
Offline lucky
« Reply #6 on: November 02, 2012, 04:25:58 PM »
Get the AVON Roadrider 26 tires.
Front is ( reversable) 100/90-19
130/80-17 for the rear.
Offline JimS63
« Reply #7 on: November 02, 2012, 06:05:27 PM »
I have a 1977 CB750A with a 130/80-17 Continental tire on the rear and I have no clearance problems at all.
1977 Honda CB750a Hondamatic
Offline limerence
« Reply #8 on: November 04, 2012, 04:35:03 AM »
Lucky / JimS63 - I see that Avon makes a 130/90-17 as well. Was there a reason why you guys chose the 80 over 90 aspect ratio? Would it rub?
-John
Offline JimS63
« Reply #9 on: November 04, 2012, 08:49:49 AM »
Mine had the 130/80-17 on it when I bought the bike. I got a nail through the tread and out the sidewall, so I got a new tire (same size). I'm not sure about other sizes, but there are no close tolerances anywhere that I can see.
