Author Topic: The Vacillator build - F3 Engine  (Read 10161 times)
Re: The Vacillator build - F3 Engine
« Reply #25 on: October 08, 2013, 08:11:53 AM »
This will help you decide what you have.
Perfect.  I'm all F2!  ;D
Offline brandEn
« Reply #26 on: October 08, 2013, 08:15:58 AM »
Oh yea, as for the bucket o bolts. One thing I found is that most the bolts will only fit in one location so its hard to get them mixed up. I am sure you know this but the parts fiche lists all the bolt lengths and also helps when it comes time to put it together. I bought one of those bolt sizing cards at ACE and I use it ALL the time to determine lengths.
« Reply #27 on: October 08, 2013, 08:20:13 AM »
I just put "bearings" into Google and hit maps. Found a place near me that sells them and went down there. For the grooved bearings I ordered from Yamiya. If you do this make sure they don't use UPS or you will have a TON of customs paperwork to fill out.
sweet.  imagining shipping costs more than the bearings themselves  ::)  thanks.
yeah, i have the fiche and a sizing card handy and was just going to use it to start fresh.  a bunch of the heads were eff'd up during removal, and a set of new ones wont break the bank. looks cleaner, too.
« Reply #28 on: October 08, 2013, 05:17:03 PM »
Let the fun begin again!
Is that a 410 head or a 392 head? It wasn't/isn't black? What size are the intake and exhaust valves? Are there numbers cast onto the top fin intake side by #3?
410
In. 34.5mm
Ex. 32.0mm
(Not exact measurements as I have not removed the valves)
Finally got the last of the studs out, and finished cleaning the upper case and mating surface.
« Reply #29 on: October 08, 2013, 07:42:52 PM »
I think that's enough verification of a F2/F3.
Check the guides then start assembly. Are you going with HD studs? It's a good idea.
« Reply #30 on: October 09, 2013, 03:12:42 AM »
Valves too, exhaust valves on mine had 1mm+ dimples from rocker arms.
« Reply #31 on: October 09, 2013, 09:58:22 AM »
No dimples  :)
Yes, I plan on ordering HD studs, bronze guides, and new seals.  I dont know if the current guides are new or reused.
I noticed there are green/black/red seals.  One better than the other?
leaning towards the red KPMI viton ones from dynoman.
amassing a list of parts to order  :o  hate multiple shipping charges.
and what's this number?  ...painted on the lower left case next to the filter.
« Last Edit: October 09, 2013, 11:08:22 AM by flybox1 »
Offline brandEn
« Reply #32 on: October 09, 2013, 11:21:03 AM »
MRieck posted a thread recently on valve seals comparing them. He found the OEM seals are the best in his opinion. Apparently the aftermarket seals are taller and don't seal as well.
« Reply #33 on: October 09, 2013, 12:26:31 PM »
sweet.  there goes an extra $50  ;D
Offline brandEn
« Reply #34 on: October 09, 2013, 03:13:40 PM »
He said the aftermarket seals aren't as good with a high lift cam...
http://forums.sohc4.net/index.php?topic=119918.0
I have a set of guide seals and a base gasket as well as a head gasket. Yours if you want em
« Last Edit: October 09, 2013, 03:16:00 PM by brandEn »
« Reply #35 on: October 09, 2013, 04:52:36 PM »
SOLD! I'll throw in a IPA sampler  8)  Help you heal your gut.
I'll pm you soon and come and get them.  Thanks bud.
Offline brandEn
« Reply #36 on: October 09, 2013, 05:03:19 PM »
Right on, but I will ship them if you like. That's a 2.5 hour round trip!
« Reply #37 on: October 12, 2013, 01:25:19 PM »
Couple of things going on today.
Top case painted and head torn down....but I have one valve not wanting to come all the way through the guide.  It sticks right there.  New guides going in, but I don't want to ruin the valve.
What to do?  :-\
Re: The Vacillator build - F3 Engine -valve stuck...help!
« Reply #38 on: October 12, 2013, 01:55:26 PM »
The valve end is probably little mashroomed. Measure it with caliper - shoudl be 6.5 mm - and grind it away.
I bet it is exhaust valve, right? I had to grind 3 of my exhaust valves.
« Reply #39 on: October 12, 2013, 02:18:26 PM »
Intake #4, and it mics at 6.53mm.
Valve end shows no wear...
Took my wheel to it and after a bit of work, it pulled through.
here comes a cycle x head rebuild kit  ::)
« Last Edit: October 14, 2013, 07:39:43 AM by flybox1 »
