Author Topic: How to soften hardened rubber airfilter box to carbs  (Read 3589 times)
Offline Vincent P
« on: March 09, 2013, 05:13:49 PM »
It's been a couple of years since I've run my 73 CB750 with the air cleaner assembly, but after doing a ground up restore of it, I've decided to put the air filter box unit back on. The rubber tubes going from the box to the carbs have hardened.
Do any of you know how I could soften these back up???
They seem to be a hard item to locate as replacement, so I'm looking at a DIY remedy.
1973 Honda CB750 K3
Offline DJ_AX
Re: How to soften hardened rubber airfilter box to carbs
« Reply #1 on: March 09, 2013, 05:18:32 PM »
I tried the "wintergreen oil" method on mine.. (search it) ... but they we're already in sad shape with rips and tears ... just made it worse ... it worked great on the heavy rubber between the carbs and the engine...
I ended up just buying some from... parts n more I think .. ??? it's been a couple years..
Offline Vincent P
« Reply #2 on: March 09, 2013, 05:20:37 PM »
Thanks DJ,
I will research this; I would love to buy a replacement set, but they seem to be a hard item to find!!!
1973 Honda CB750 K3
Offline Gregorymoto
  • SOHC Aficionado
« Reply #3 on: March 09, 2013, 05:27:20 PM »
By new re-pros and save your self a lode time.
http://www.davidsilverspares.co.uk/CB750K4-FOUR-1974-USA/part_105501/
Yep, i have issues with this sort of stuff.
Offline Vincent P
« Reply #4 on: March 09, 2013, 05:42:36 PM »
Thanks for the link  :)
1973 Honda CB750 K3
Offline KC_Northstar
« Reply #5 on: March 09, 2013, 05:59:08 PM »
Thanks DJ,
Like so many of the parts for the cb750K they are still available from Honda.  $7.50 each.
http://www.hondabike.com/fiche_select1.asp?cat=Motorcycles&mfg=Honda
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #6 on: March 09, 2013, 06:19:58 PM »
I just received a set of repros that I bought on ebay from a seller named kenosha_kid.  From Germany $34 shipped.  They arrived the other day and were exactly as advertised.
http://www.ebay.com/itm/280623838800?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Offline Untold
« Reply #7 on: March 09, 2013, 06:20:23 PM »
I just soaked mine overnight in straight xylene.  Worked pretty well.
1976 CB550K
Offline brewsky
« Reply #8 on: March 09, 2013, 06:23:31 PM »
Heating them with a hair dryer and put some silicone spray, wd40 or the like works well for me.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Vincent P
« Reply #9 on: March 10, 2013, 03:59:36 AM »
Thanks for the links all and the tips; much appreciated.
1973 Honda CB750 K3
Offline Gregorymoto
  • SOHC Aficionado
« Reply #10 on: March 10, 2013, 12:15:45 PM »
Works well for how long? Trust me. If you have the money just buy new ones. When rubber goes it goes. There is no real fix. Soaking in X just brakes the rubber down a bit and makes it softer. That a temp fix. It might work for a month or even 5 years If you never take your carbs off. Ya, buy new ones take care of them and save your self time and energy down the road, or time and energy on the side of the rode.
Good luck all
