Author Topic: Do carb sync hoses need to be fuel-proof?  (Read 805 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 12, 2013, 09:19:58 AM »
Borrowed Spanner1's carb sync gauges but his hoses are starting to split at the end. Does the replacement hose need to be fuel-proof or can I just use regular vacuum hose?
Offline Roach Carver
Re: Do carb sync hoses need to be fuel-proof?
« Reply #1 on: March 12, 2013, 09:30:34 AM »
I would say regular clear/vinyl hose should be fine. You are checking vacuum. I don't think fuel will enter those lines. even if it did, for the limited exposure time I doubt it would matter.  ****** Disclaimer, I have never vac-synced my carbs**** I only replied since no one else has so heres a bump for you and hopefully we will get confirmation from another member that I am brilliant and correct.
« Reply #2 on: March 12, 2013, 09:35:27 AM »
I used clear vinyl hoses for my synchro tool, but later went to rubber - it stays softer longer and is easier to put on and off carb adapters.
Offline iron_worker
« Reply #3 on: March 12, 2013, 09:37:55 AM »
Vacuum hose should be fine.
IW
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: March 12, 2013, 09:43:14 AM »
That's what I thought; but since they belong to someone else I wanted to make sure. Thanks y'all!
« Reply #5 on: March 12, 2013, 09:52:44 AM »
Unless something is really wrong the gas vapors are going the other way. Vinyl is probably not apt to seal as well as rubber. That reminds me I have to replace mine. Thanks for the reminder!
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #6 on: March 12, 2013, 09:54:14 AM »
I'm here to help :)
