Author Topic: Main Jet Recommendation for CB550 with Mods  (Read 1715 times)
Offline Cut
  • CHARLIE DONT SURF !!
« on: March 26, 2013, 07:29:43 PM »
Just finished rebuilding the top end on my 75 CB550K1 and am looking for anyone who is running a similar setup to mine to chime in and let me know what jetting is performing well so that I can save time/money dialing her in with the modifications that I have made since the rebuild.  My configuration is as follows:
650 Cam
Steel Dragon Velocity Stacks
4 into 2 Exhaust (Jardine)
Everything else is stock.  Thanks in advance!
1975 CB550k1 (Hot Wifes Ride)
2012 BMW F800GS
1968 CB450 Bomber (Restoration Project)
Re: Main Jet Recommendation for CB550 with Mods
« Reply #1 on: March 27, 2013, 12:31:04 AM »
run the stock jets first and go from there,the stacks might cause some sorting by themselves.
Offline Cut
« Reply #2 on: March 27, 2013, 12:25:31 PM »
Mike from Steel Dragon Performance stated that his clients are reporting that 115 mains are working well for them on the CB550.
2012 BMW F800GS
« Reply #3 on: March 27, 2013, 12:35:41 PM »
your results may vary,start with the stock jets and go from there,yours might only need a more subtle increase in jet size,some people think their bikes run great but theyve missed the mark and they run #$%*.
« Last Edit: March 27, 2013, 12:38:34 PM by dave500 »
Offline lucky
« Reply #4 on: March 27, 2013, 01:22:30 PM »
With velocity stacks I would go up on the main, and lower the clip on the slide needle one notch.
Offline Cut
« Reply #5 on: March 27, 2013, 04:43:54 PM »
Copy all and will have 100s/105s/110s and 115s at the ready.  Will drop the needle jet a notch if I get a drop in performance in the mid-range.  I think dropping the needle a notch is recommended anyhow.  Will post back in a day or two.  Kudo's!
2012 BMW F800GS
« Reply #6 on: March 27, 2013, 10:42:30 PM »
do one change at a time!!say swap the main jet but dont touch the needle yet,,this is where people get it so wrong!they start twidling everything at once.
