Author Topic: Cb750 Cylinder Head Dimensions  (Read 3109 times)
Offline CB750F2
  • Pat's first Honda 750 F2
« on: April 04, 2013, 03:47:14 PM »
I have acquired a K4 cylinder head which I intend to fit to my F2 which has been rebored to 836 and fitted with flat topped pistons. The combustion chambers measure 22.3cc. I expected 19.5cc for an unmodified head. The valve guides are fine but the inlet valves appear to sit high in the chamber. I have some questions:
1          What is the dimension between the head gasket sealing surface and the valve cover surface? I am trying
             determine how much - if any - has been milled from the head.
2           Is there any other way to determine how much has been milled from the head?
3           As I said earlier the inlet valves appear to sit high in the combustion chamber and may account for some
              of the extra volume that I am measuring. Is there a maximum length that the valve stems protrude
              through the guides? If so what is the length?
4           I see that Cyclexchange has oversized valves - Part No ENV-16A - that can be fitted to these heads. Would
             fitting a set of these on the inlet side together with remachining of the seats be a fix. I would think that this
             would improve performance and reduce chamber volume.
I look forward to your feedback. Thanks, Pat
Regards
Pat from Australia
Offline CB750F2
Re: Cb750 Cylinder Head Dimensions
« Reply #1 on: April 04, 2013, 05:21:28 PM »
The Cyclexchange site has given me the answer to question 1 - 73.27mm. Can anyone confirm this? Mine is 72.3mm so it has approx. 1mm removed. Pat
Regards
Pat from Australia
Offline kmb69
« Reply #2 on: April 04, 2013, 06:43:38 PM »
I just measured 2) NOS 750K heads and they both measured 72.37. Is your 73.27 a typo? Maybe your head has not been milled.
Offline CB750F2
« Reply #3 on: April 04, 2013, 06:54:21 PM »
Thanks for your reply KMB. I have rechecked the Cyclex site and they say 73.27mm. I also have two heads that measure 72.3mm with a set of vernier calipers. Hopefully others will reply. Pat
Regards
Pat from Australia
Offline kmb69
« Reply #4 on: April 04, 2013, 07:06:26 PM »
I think they transposed the 2 and the 3 on their website. Will check with Ken tomorrow.
Offline CB750F2
« Reply #5 on: April 04, 2013, 07:24:35 PM »
Ok Thanks. I also have an F2 head that measures 72.3mm. So I have three heads - K4, 392 and a 410 - that measue 72.3mm. The chamber volumes are: K4 - 22.3cc, 392 - 22.8cc, 410 - 28.5cc. The 410 head does not look as if it has been messed with but the other two look to have some de-shrouding done. Pat
Regards
Pat from Australia
Offline CB750F2
« Reply #6 on: April 05, 2013, 03:43:43 PM »
Anybody?
Regards
Pat from Australia
Offline CB750F2
« Reply #7 on: April 05, 2013, 08:30:58 PM »
Bump again
Regards
Pat from Australia
Offline CB750F2
« Reply #8 on: April 07, 2013, 02:40:24 PM »
Can anybody help?
Regards
Pat from Australia
« Reply #9 on: April 07, 2013, 03:43:57 PM »
Pat, send Mike Rieck a PM, he's the resident head guru, if he doesn't know , no one does.... ;)
http://forums.sohc4.net/index.php?action=profile;u=49
Offline CB750F2
« Reply #10 on: April 07, 2013, 05:33:03 PM »
Thanks Retro. I will do that if no one else replies today. Pat
Regards
Pat from Australia
Offline CB750F2
« Reply #11 on: April 08, 2013, 01:19:55 PM »
Bump again.
Regards
Pat from Australia
