Author Topic: Easy install of a bank of 4 carbs.......................  (Read 7694 times)
Offline 55 Truck
« on: May 07, 2013, 11:42:37 AM »
I recently used two pieces of sheet metal to help install my 4 carbs on a 1976 CB550F. The principal here is to create a trough for the carbs to travel in. Do this by cutting two pieces of light guage sheet metal to a size of 3 inches by 12 inches. Hold one of them in front of the intake manifolds and the other in front of the air box intakes. Then have someone else to slide the carbs in between the two strips of sheet metal till they are lined up and in place. Then simply slide the two pieces of sheet metal out, pop the carbs into the intake boots and the air box boots and Wa-La, your done....................
« Last Edit: May 16, 2013, 01:52:23 PM by 55 Truck »
Offline ncstatecamp
Re: Easy install of a bank of 4 carbs.......................
« Reply #1 on: May 16, 2013, 12:42:39 AM »
I popped one side on fine then used a ratchet strap and 2x4 to pop the rest in.
Offline 55 Truck
« Reply #2 on: May 16, 2013, 01:44:23 PM »
If your talking about "popping" them into the intake boots, thats not what I am describing. I am talking about actually getting the carbs to fit in between the intake and airbox boots. You have to do that before you can "pop" them in..................
Offline ncstatecamp
« Reply #3 on: May 16, 2013, 01:45:22 PM »
Ah ok nvm then carry on
Offline streak09
  • I don't know what im doing, but I'll do it anyway
« Reply #4 on: September 30, 2013, 09:33:12 AM »
Just saw this. I am definitely trying this when I install mine next time, those things are a you know what!  >:(
Offline nccb
  • 1974 CB750 Four
« Reply #5 on: September 30, 2013, 10:03:55 AM »
I'm having a hard time visualizing this.  Care to draw up a schematic :D
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: April 11, 2014, 02:41:43 PM »
I find it easier to unbolt the intakes and take the carb rack off with the intakes as one unit. I do it all the time and it's the easiest way I have found yet.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Stilltime
  • Building my Dream
« Reply #7 on: April 11, 2014, 03:23:14 PM »
+1 mine will come right off and back on when you pull the manifolds too.
'78 CB550 - Orange Crush
Offline kiwikk
  • Plumbing by Michelotti
« Reply #8 on: June 19, 2014, 12:33:29 AM »
Like that sheet metal solution. Minimal removal work involved. Might try it next time.
I've tried the airbox strapping technique for removal but didn't like it so I removed the airbox as per the manual.
Most difficult bit is getting to screw on the oval clip at the back of the airbox.
Inside the air filter chamber there's a removable insert (see photo). Pull it back clear of the airbox clip and the airbox will slide out right easy leaving loads of space for carb removal.  :)
Offline windsurfed
« Reply #9 on: February 09, 2015, 07:42:35 PM »
I get the concept.  Like to see a video of you doing it.  It's always been a hard thing to do.  Next time I have to do it, which hopefully will be never, I'll use that method.
Stupid is a Choice, Dumb is not a Choice.  Stupid can be fixed!  Dumb cannot be Fixed!
« Reply #10 on: April 23, 2016, 08:52:42 AM »
 If the carbs dont line up, loosen the rubbers and twist to line them up, leave them loose till after install. They must go on first.
