Author Topic: Think these cb400 cables will fit a cb350f  (Read 790 times)
Offline andy8190
Offline hoodellyhoo
  • CB350F
Re: Think these cb400 cables will fit a cb350f
« Reply #1 on: May 21, 2013, 04:41:44 AM »
Seems like it would work to me since you're running clip-ons
Offline Matt Chapter
  • spin it up!
« Reply #2 on: May 21, 2013, 09:27:17 AM »
The 350 and 400 share most parts, except the obvious.. you know, the stickers that say 350 or 400.  As long as the cables are not for the U.S. '77 model (which had higher handle bars) you should be fine.
'86 R65 '76 CB400F
Online dave500
« Reply #3 on: May 21, 2013, 12:51:33 PM »
they have different part numbers,unless you can see a pair side by side get the correct ones.
Offline Bodi
« Reply #4 on: May 21, 2013, 01:35:00 PM »
Carb cables sould work, length is the only difference. Clutch cable is totally different 400/350.
