Author Topic: CB500 carburetor - Found what was broken and why I can't pass emissions (PICS)  (Read 5406 times)
Offline harisuluv
It is common to have SOME corrosion on the main jet tube.  It will only matter if it extends pass the main jet o-ring and compromises the seal.  As a general rule, if you can't see the o-ring it is probably ok.  All rules have exceptions though and you need to inspect everything.
Offline seventythreecb
So had a minute to get into the carbs this evening.
Mainjet=115
Pilot=40
I have a bag of carb parts from the po and in it I found 5 100 mainjets and 3 98 mainjets???????
I'll pull the O-ring y'all were talking about tomorrow and check them out.
So, If i am running rich, The mainjets are my problem? Makes sense to me.
Attached are images of the #3 carb... I can see the rubber on the main jet....
Thanks again
Patrick
Offline MoMo
  • Ride like you're invisible
Not good!  either replace the body or get it mircro welded .  One person I know of who does the latter is forum member Jim French...Larry
Offline motosan
Wow, from the earlier picture it looked like the breakage wasn't significant enough to expose the o-ring, but this is pretty bad.  Since you have the spare, the cheapest/quickest/easiest way might be just swapping them......
77 CB550K (PD46a)
04 CBR600F4i
05 FZ600
Another unfortunate turn of events.... My other vehicle is down now!!!! Radiator is old and sprung a leak... Pulling in tonight. hopefully can repair, but i am not optimistic.
So, got to get the bike running for work next week. Hopefully, get this radiator problem sorted out.
Harisuluv informed me that I have a #2 and a #4 Carb, so we will be trading my #4 for his #3 next weekend.
Ya'll have been a great help,
Hope I can return the favor some day.
Patrick
Harisuluv is the MAN! He's sure got lots of the carbs. So does Bill Benton.
