Author Topic: Regearing a 650C  (Read 849 times)
Offline wardenerd
  • '77 550F '81 650C
Regearing a 650C
« on: June 28, 2013, 04:30:48 AM »
My 650C runs great and I want to use it to ride longer distances.  I was thinking that a larger drive sprocket would reduce the RPM to a reasonable level at 70 to 75 moles per hour. I have a rev commander webpage that says the RPM at 75 will be reduced by 800 RPM if I go from 17 stock tooth sprocket to 19 tooth sprcket.  Has anyone done this with their bike of any size and what was the effect on stops and starts?
Offline tomkimberly
Re: Regearing a 650C
« Reply #1 on: June 28, 2013, 12:22:16 PM »
I don't think there is enough room to use a 19 tooth sprocket.
You might look into reducing the number of teeth on the rear one.
Tom
Offline curemode2002
« Reply #2 on: June 28, 2013, 12:38:09 PM »
+1 the 17 is stock on the Customs if I remember right and they are pretty big especially with the chain on.
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline trueblue
« Reply #3 on: June 29, 2013, 12:32:48 AM »
Let it rev, won't hurt it a bit.  Mine has done numerous days sitting between 6-7k and it seems a lot happier there than at 5k and below ;D
They're not Harleys ;)
1979 CB650Z
Offline cb650
« Reply #4 on: June 29, 2013, 03:26:57 AM »
I put a 18 on mine.  A couple I have had to modify the chain guard under the cover but a couple not.  19 I think would be to big and too much for the engine depending on the rear.
