Author Topic: cb550f parts on k  (Read 896 times)
Offline turboed13b
cb550f parts on k
« on: July 04, 2013, 04:51:23 PM »
Ok, I have a cb550 everything is f but the frame is a k. I want to run the stock 4-1 header. I have already torn down the frame and motor so I can't check for myself at the moment about some things.
Does the header hit the k peg?
Will the f kick start keep it from hitting the header?
If the f kick start works will it hit the k peg?
Lastly if it does hit the k peg will a f peg work?
Edit: One more, are the f brake pedal and peg physically in different positions on the f frame?
I saw a picture but can't tell but it looks like only the peg is in a different spot on the frame meaning I can weld a new bolt to the frame. With the brake I can extend the brake tube mount and it should work?
« Last Edit: July 04, 2013, 05:12:11 PM by turboed13b »
Re: cb550f parts on k
« Reply #1 on: July 04, 2013, 11:35:22 PM »
77/78 K frame is totally different I think the up to 76 K is same as F but not 100% sure
« Reply #2 on: July 05, 2013, 01:09:55 AM »
theres two frames on 500/550s,,the early or first 550s were the same frame as 500s,different forks/instruments and whatever but the frame is the same,the later k and f have the same frames,but different exhaust and mudguard stays etc,the super sport or f has an oddball brake pedal to clear the pipes,and right hand peg and a kicker to clear it.
Offline turboed13b
« Reply #3 on: July 05, 2013, 02:39:53 PM »
Hmm I thought the k frames had the foot peg mounted in a different place than the f. Anyone have a picture of the later model k frame where the right foot peg would be?
