Author Topic: WHERE DOES THE HOSE GO on CB650  (Read 2192 times)
Offline nivlac
  • Old, bold and startin' to mold
« on: July 15, 2013, 08:32:55 AM »
LOOKING FOR THE LOCATION FOR THE OTHER END OF BREATHER HOSE ON A 79 CB650. I SEE A NIPPLE END ON THE RIGHT SIDE OF THE VALVE COVER. FROM THERE TO WHERE?
Offline JACKOCASTER75CB550K
Re: WHERE DOES THE HOSE GO on CB650
« Reply #1 on: July 15, 2013, 08:40:41 AM »
Goes down behind the wheel where all the drain hoses are from the carbs and battery..
Offline nivlac
« Reply #2 on: July 15, 2013, 10:10:43 AM »
I'm feeling pressure coming from this fitting. Is it going down to the drain area and just suspended or is it attached to another item?
« Reply #3 on: July 15, 2013, 10:16:27 AM »
Drain area and just suspending
Offline Tdinova
« Reply #4 on: July 15, 2013, 10:42:12 AM »
The hose connects to the valve cover which connect to the air breather box. That will recirculate the blow-by gas from the engine. Then there is a hose connected to the bottom of the air box for oil waste which should be emptied 1-2 a year. In Canada the hose is left open to drain into our water streams..
http://www.buymotorcycleparts.com/honda_parts.htm?aribrand=HOM#/Honda/CB650_A_%2880%29_MOTORCYCLE%2c_JPN%2c_VIN%23_RC05-2100002_TO_RC05-2108005/AIR_CLEANER/CB650-80-JPN-A/2Y14460AF14460A17B
Part #8 is from valve cover to air box
Part 7 is from air box to waste
Is this what you want?
Blair
Nova Scotia, Canada
Offline Tdinova
Blair
Nova Scotia, Canada
Offline Tdinova
« Reply #6 on: July 15, 2013, 10:49:40 AM »
http://www.bikebandit.com/houseofmotorcycles/1979-honda-cb650/o/m9572#sch403716
Just re read your post. Yours is a 79 my son has a 80.. huge difference..
sorry
Blair
Nova Scotia, Canada
Offline nivlac
« Reply #7 on: July 15, 2013, 03:41:06 PM »
Thanks
Offline trueblue
« Reply #8 on: July 16, 2013, 05:39:10 AM »
My 79 goes from the valve cover to the airbox
1979 CB650Z
