Author Topic: 75 CB550 is not Cooperating  (Read 4257 times)
Offline jo_ma_ma
  • formless and void
« on: August 20, 2013, 05:04:35 PM »
Hi guys.  I have been using the information off this site for a long time, but decided to post some questions.  Thanks for what you are doing - most of the information here has been very useful.
Alright, so I have a 75 honda cb550.  I've had it for years... I rode it a while back (7 years ago maybe) at my parents suburb... then I graduated college, forgot about it for a while, then I remembered again, and decided to restore it and ride it... Well, then I remembered that I didn't have the title, so I had to apply for the title... and that was gonna take a while... all summer in fact...  In the mean time I thought I'd fix all that's wrong with the bike and by the time I get the title, I'll have a working bike, and I'll ride it around Chicago in the evenings... take my wife for ice cream...
First, I read a bunch of posts on this here website, then went ahead and pulled out and cleaned the carburetors and changed the oil, and replaced the cables, spark plugs, battery, checked the timing, cleaned the air filter, replaced the handlebars, cleaned and polished... cleaned and polished everything.
After completing all those tasks, the bike finally started for the first time in years... and that was great.  At first only one side ran.  I thought it was the coils and took them out... and then the guy at zenterprise.com told me it is likely not the coils, so I connected the coils back.  I took apart the tank thinking it was clogged and wasn't sending fuel into the carbs.  A week later I tried it again, and it ran with all 4 cylinders!  It ran at about 3000 rpm's, though...  I connected the vacuum tool and synchronized the carburetors, and the bike ran great... although it still ran at around 3000 rpm's.  I thought I'd take it for a ride and that would help the bike run better and help the rpm's to go down.
So this past weekend I got the title, finally, and drove to my parents' (where the bike lives now), and put on my helmet... and the Honda did not start...  So... I know it's all about the spark, the timing, the air, and the fuel mixture... but I thought I sorted all that out.    It has the spark... the carbs are clean... it ran 3 weeks ago... I don't know what to do with it anymore... it is supposed to be reliable and tough...  What I don't want to happen is bring the bike where I live (no garage), and have it just sit there and not be able to start...
Please let me know if you guys can suggest anything... to help me get this bike on the road... but, mostly, thanks for the opportunity to write and post this here...
Ale.
Offline jo_ma_ma
  • formless and void
Re: 75 CB550 is not Cooperating
« Reply #1 on: August 20, 2013, 05:06:40 PM »
By the way, here are some photos of my Honda.
Offline Mo
« Reply #2 on: August 20, 2013, 06:32:25 PM »
Have you checked the battery voltage?
Offline Vinhead1957
« Reply #3 on: August 20, 2013, 07:43:59 PM »
Check fuel filter and bowls to make sure fuel is present. Pull a plug to see if its wet or dry
Offline Joemac
« Reply #4 on: August 20, 2013, 08:40:44 PM »
+1
I had problems with old school unsealed batteries all the time.  Bought a sealed Scorpion battery, changed my life....my battery life that is. HOHO
« Reply #5 on: August 20, 2013, 11:08:11 PM »
The individual slide adjusters can be skewed so that the slide can lower far enough to allow the idle screw to set the slide opening.  When you reassembled the carbs did you ensure that the slide barrels can completely shut off inlet flow with the idle knob backed out?
If not, this is the likely reason that it won't idle below 3000 RPM.  Unless...
Are you saying that you must set the idle at 3000 or the engine will die?  If that is the case then the pilot jets or the pilot jet circuits in the carbs are probably still blocked.
"Did not start"  Is a pretty non-descript statement, which may or may not include:
The starter won't operate electrically.
The starter won't spin the engine.
The engine spins but doesn't fire the cylinders.
The engine fires but won't keep running on its own.
If you dismantled the fuel valve for the tank, did you recover and check the filter?  Are you sure the valve and filter were assembled correctly?
Do check the STOP-RUN-STOP switch setting.
Check for gas in the tank, and that the "reserve" position operates as it should.
And...
Don't blame the machine for a mechanic deficiency.  The bike can teach you a lot.  But, it won't teach you everything.  It is the mechanic that is supposed to teach the bike how to behave properly.
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: August 21, 2013, 01:45:42 AM »
And...
[/quote]
 ;)  ;D...Larry
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: August 21, 2013, 02:04:57 PM »
Sweet looking original 75! A set of OEM 4 x 4 pipes will make that thing super cherry.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline goldarrow
  • one day, i'll be an
« Reply #8 on: August 21, 2013, 02:13:19 PM »
i'll arrange a shipping company to come out to you and pick up the bike, ship it to me and i'll help you get it running again.  once i get your bike, i will first check the battery and see if at least i can get any lights to come on.
CB550 K0
Offline jo_ma_ma
  • formless and void
« Reply #9 on: August 21, 2013, 07:43:09 PM »
I'll do that...  Last I checked the plugs were wet... then I adjusted the air mixture screws... the suggested number of turns... and that helped... then I synchronized the carbs and thought that took care of that... I'll have to pull the plugs again... this weekend...  Thanks for your reply, man!
Offline jo_ma_ma
  • formless and void
« Reply #10 on: August 21, 2013, 07:51:18 PM »
And...
Thanks for suggesstions, TwoTired!  I'll check to make sure the fuel flows to the carbs...  The engine turns, it almost starts... but won't keep going.  I think this might be related to fuel not getting in there... too lean... but I'll know this weekend once I pull the plugs out.  Thank you!  Oh, and I am not blaming the bike... it's a piece of equipment... I just really want to make it work... I've seen so many photos of these vintage motorcycles that you guys put together... and just want to make a contribution, so to speak... to the collective call to keep these machines alive.. hehe.
Offline jo_ma_ma
  • formless and void
« Reply #11 on: August 21, 2013, 07:53:47 PM »
Thanks goldarrow!  It would definitely be nice to get a second set of brains to help with this... but having all of you guys contributing is a hell of an encouragement.  Thank you.
Offline jo_ma_ma
  • formless and void
« Reply #12 on: August 21, 2013, 07:56:17 PM »
Thank you Duanob!
Offline jo_ma_ma
  • formless and void
« Reply #13 on: August 30, 2013, 07:28:00 PM »
Alright, guys.  I thought about all your posts, and I went to my parents last weekend, and I measured the battery output - it turned out to be 11.4 volts.  Figuring that must be too low (and understanding now why the bike started from a car battery), I hooked up the car battery to it again, cranked the engine to no avail for several tries.  But then it just fired up!  It did it so easily, too - just as if it was a daily commuter!  It just worked... kept going and going.  The rpm's were high, but I let her run for a while... to warm up the engine and burn off all the stuff it may have accumulated in the carburetors, etc.   After the bike warmed up, I adjusted the rpm's to about 1800, and that was that.  I then took the bike for a run.  Boy was that fun?  I completely forgot how exciting it is to ride motorcycles (it's been a few years).  Anyway, it's a really good feeling - to spend time on something, and then have it give you all this pleasure back (I'm sure most of you are familiar with that feeling).  I rode the bike for about 20-30 minutes, and it just kept getting better and better.  I stalled a couple of times, and the bike started without the car battery... really easily.  I asked my dad to start it up every day and ride it so it keeps the momentum.  This weekend I am going to visit my folks again and I really look forward to riding the bike.
Thank you all for support!
Ale...
Offline Tews19
  • I am no
« Reply #14 on: August 30, 2013, 07:32:12 PM »
Car battery????
Yikes do not do that.. Just like you should never jump it with a car either...
Did you slap yo_ma_ma?
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
« Reply #15 on: August 30, 2013, 07:33:46 PM »
God darn it!!!! Freakin auto correct for these stupid SMART phones!!!!
I meant in a joking matter, " did you slap it jo_ma_ma"? as in the bike to behave properly?
Offline jo_ma_ma
  • formless and void
« Reply #16 on: August 30, 2013, 07:41:33 PM »
Wait, forgot something: what is a good place to purchase a kit to rebuild the master cylinder, do you guys know?  I placed the order with the fella who sells brake hoses through slingshot-cycles (the member discount is very cool, by the way), but I figured I might as well get the brakes sorted all the way.  I looked around online and the prices vary greatly; perhaps someone can recommend a place that's proven itself.
Also, do I need to replace the piston that's inside the assembly?  I've seen this dude on youtube just replace the gaskets and clean everything and just put the same metal parts (the piston, the spring and a retainer clip) back.  The kit I saw online come with the piston and the gaskets, and another gasket for a different Honda bike... too many pieces... I was hoping to get just what's necessary and pay for just that.
Another question: what do you guys know about EBC brake pads for these motorcycles?  I have them on my car and I really like them.  They cost like 10 bucks more... but if they are gentler on the disk, perhaps it's worth investing the extra... for the long run.  If you know a good brake pad (and the brake shoe for the rear), please let me know.
Have a good holiday (if you're in US), and good weekend to you all!
Ale.
« Reply #17 on: August 30, 2013, 07:41:33 PM »
Using a car battery can be done safely is you do NOT have the car running and are using booster cables. But not if the battery is not present or has a bad cell.
Offline jo_ma_ma
  • formless and void
« Reply #18 on: August 30, 2013, 07:47:06 PM »
Yeah, I had to electrocute the hell out of it, pretty much :-)  but it worked!
Offline Tews19
  • I am no
« Reply #19 on: August 30, 2013, 07:49:29 PM »
Rebuild kits range from 20-50 bucks....Check out David Silver Spares website... You can get an after market master cylinder for like 60 bucks.. Bolts right on and works great...
« Reply #20 on: August 30, 2013, 07:50:22 PM »
Why not spend a bit more and buy a new repro brake master cylinder from David Silvers Spares here in the US, it is around $60 if I recall correctly.
Online bryanj
« Reply #21 on: August 31, 2013, 07:11:05 AM »
 I don't know of anybody that can re-use that damn circlip as its so awkward to get out its usually bent!!
OK my 2 cents on batteries,
I, like most, used to buy the cheapest i could find as i don't ride much anymore but 18 months ago, on advice froma good dealer friend of mine, i spent the extra 25% and bought a Yuasa had it filled and charged for a day.
Last week after standing for 10 months I just turned on the gas and choke let it sit and the starter turned it over for a good few minutes till it fired---that would never have happened with a "Cheapie" battery
Offline MoMo
« Reply #22 on: August 31, 2013, 11:38:39 AM »
Agree on the battery.  No more cheapies for me either, no more acid filled batteries too -the small amount of extra money they cost is well worth the prevention of acid damage...Larry
Offline lucky
« Reply #23 on: August 31, 2013, 11:59:50 AM »
Are the idle jets clear? Can you see daylight through them?
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #24 on: September 01, 2013, 12:26:35 AM »
Car battery????
Can you explain why not for me please? I'd love to know  :-\
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
