Author Topic: Restoring, but not over-restoring, engine covers?  (Read 2631 times)
Offline Scott S
« on: August 27, 2013, 07:09:31 PM »
 I know the engine covers were lightly polished and then clear coated from the factory. I've got a place that does awesome aluminum polishing, but what's everybody's trick for simply restoring the covers? Is there a way to bring them back to as close to the factory finish as possible?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Restoring, but not over-restoring, engine covers?
« Reply #1 on: August 27, 2013, 08:09:43 PM »
sand to about 320 grit, then hit 'em with red scotchbrite...this will get you in the ballpark....certainly not concourse.  Also, factory aluminum was clear coated...
Offline bjbuchanan
« Reply #2 on: August 27, 2013, 08:17:58 PM »
I sand thru the bad crap and then hit them with a wire wheel. I have a dremel and like to use the carbon steel wire wheel, nice light polished look to it.
Offline scunny
  • don't call me expert
« Reply #3 on: August 28, 2013, 12:43:29 AM »
+1 on the scotchbrite, adds a nice brushed look if you aren't into highly polished. then mothers aluminum mag wheel polish to seal it. only have to redo the polish occasionally.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Scott S
« Reply #4 on: August 28, 2013, 03:18:41 AM »
 Cool. I can do that and probably not have to remove the stuff from the bike. Worth a shot, anyway.
 Were the forks done in this same manner?
'71 CB500 K0
'81 Yamaha XS650
Offline DanJ
« Reply #5 on: August 28, 2013, 04:15:47 AM »
A buddy of mine who does some pretty awesome restorations on dirt bikes say polish the hell out of them then sandblast with fine walnut shells.
« Reply #6 on: August 28, 2013, 08:22:56 AM »
kinda sounds backwards...
« Reply #7 on: August 28, 2013, 08:35:08 AM »
Half true.  They were certainly clear coated.  But, it was a "brushed" finish.  Like what you get from fine sandpaper or Scothcbrite.
Clear coat won't grab onto highly polished surfaces.  To make the tiny scratches uniformly shallow, they were probably polished first, though.  So deeper grooves from coarser grit didn't alter the final visual effect.
Offline DanJ
« Reply #8 on: August 28, 2013, 08:44:45 AM »
I guess the fine walnut just takes the high gloss off and leaves a nice finish. I haven't tried it but the guy does nice work and I have no reason to doubt him.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: August 28, 2013, 09:10:45 AM »
I got this finish on my drive side case by using 220, then 400, then 600, then 800, then 1,000, then 1,500 grit wet/dry paper and finishing with semi-chrome polish and a buffing wheel on a drill.
Offline Scott S
« Reply #10 on: August 28, 2013, 05:20:24 PM »
 I took these pics the other night while polishing up some chromed covers that came with my 550F. I realized that they show some NOS, unrestored parts that are a nice example of the stock finish.
 Look at the valve cover end caps in the background. I also have an NOS alternator cover, too.
'71 CB500 K0
'81 Yamaha XS650
Offline Xnavylfr
« Reply #11 on: August 29, 2013, 12:40:45 PM »
If you continue to polish with finer grit sandpaper them use SIMICHROME paste the ALT cover will look just as good as the others. Without some type of wax/polish over the shiny stuff , it will start to corrode pretty quick!!
Xnavylfr(CHUCK)
