Author Topic: Removing field windings from alternator cover  (Read 1172 times)
Offline wvshooter
« on: September 17, 2013, 04:53:23 PM »
I want to polish my alternator cover on the polish wheel. I've got the alternator cover off the motor and have removed all screws that hold the field coil in place. The field coil seems immovable. How hard should it be to get out? And once out how hard is it to get it back in?
Re: Removing field windings from alternator cover
« Reply #1 on: September 17, 2013, 05:29:18 PM »
a little corrosion may be holding it on?it should come off with a little nudge,its not magnetic,it is an electro magnet though.
Offline wvshooter
« Reply #2 on: September 18, 2013, 06:08:18 AM »
After 39 years I'm guessing corrosion.
Offline strynboen
« Reply #3 on: September 18, 2013, 06:35:26 AM »
 if is it a 400/ 500/550...it looks like this...take the elektro magenet in center aut first...and lift./.press the stator up..be care not to break the viring..i put new wiring on ..its easy to press in ..after it are cleaned for korrosion
« Last Edit: September 18, 2013, 06:40:10 AM by strynboen »
i hate all this v-w.... vords
Offline wvshooter
« Reply #4 on: September 18, 2013, 03:39:29 PM »
It's a 750 and yes it looks like the photo. Thanks for posting.
How easy is it to get out? Well, mine wasn't easy. BTW, there's nothing magnetic in there until it starts turning. It took me an hour and a half to get mine out. No corrosion, just a very snug fit. I would move the inner piece to the side so I could get my fingers under one side of the field coil. Then move to the other side and did that at least a hundred times. I turned the the unit upside down, held it in my left hand and beat on the other side with a neoprene hammer. All that did was re seat the field coil. Not cool.
I sprayed Ballistol, the slickest product known to mankind, onto the four mating surfaces. It had to help but progress was so slow who knows how much.
Anyway it's out and I can get on with polishing the cover.
Thanks everybody for the input.
« Last Edit: September 18, 2013, 03:41:51 PM by wvshooter »
« Reply #5 on: September 19, 2013, 01:00:37 AM »
the field becomes magnetic once the key is switched on,the magnetic field gets stronger once it starts turning.
