Author Topic: Tire balance  (Read 782 times)
Offline Lost and Confused
  • Bob
  • An old fart !!
Tire balance
« on: September 19, 2013, 03:00:54 PM »
When a front tire is balanced, does the disc stay on or off.
Thanks, Bob
Offline zeech
Re: Tire balance
« Reply #1 on: September 19, 2013, 03:01:45 PM »
I've done it with the disc off in the past.
Nic
Re: Tire balance
« Reply #2 on: September 19, 2013, 03:32:20 PM »
I did mine recently with the disc on, it was 35Gs out. When I rode it after that I couldn't feel any difference. We never had wheels balanced in the 70s, not to my knowledge anyway.
Offline tlbranth
Re: Tire balance
« Reply #3 on: September 19, 2013, 05:42:45 PM »
Nic is correct. Never even thought about wheel balance back when my main concern was chasing hot chicks. Now that I don't remember WHY I chased hot chicks I do balance wheels. And to do the most accurate job, you need to mount everything that's gonna be spinning with the wheel......e.g. the brake disc.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Nic
Re: Tire balance
« Reply #4 on: September 19, 2013, 06:04:55 PM »
Thanks fellow coot ;D my sentiments exactly about balancing everything on the wheel. Hot chicks, if only eh.
Re: Tire balance
« Reply #5 on: September 19, 2013, 07:00:36 PM »
I've found that the discs can have a bit of radial run-out, like about .010" in some cases. While a small about, consider that the disc weighs over 6 pounds, so shifting that 6 pounds even a tiny about off-center will affect balance. Also, the center hole in the disc is a loose fit on the hub, which can also affect balance.
IMHO, always balance with the disc attached.
Re: Tire balance
« Reply #6 on: September 19, 2013, 07:04:04 PM »
+1......with rotor
