Author Topic: 1976 CB500/550 Project "Squirrel"  (Read 340089 times)
Offline rb550four
Re: 1976 CB500/550 Project
« Reply #100 on: November 20, 2013, 07:17:05 PM »
I say back to the basics.
1 carbs are clean,we know that. Check fuel supply for stoppage or semi clog. Especially since there have been petcock issues be sure the flow is good. Do you have in line filters on? any sediment in them, any air? if there is air are they air locked? (won't totally fill with fuel. Did you re use old supply lines ? were they free of cut  or crunchy  little pieces?Did you blow them out?
2 Did you feel the pipes to see if there is a cold cylinder or 2? do they get spark? have you checked the caps to see if they are tight? The tank has been on and off a few times could you have unplugged the yellow  blue or black and white. you did ground the coils right? ( they could be unplugged and hang in the plastic jacket. ) Or the blue or yellow could have dropped out by the foot brake(tail light actuator. if that isn't it try to static time it just to be sure both points are working. have you changed out the points and condensers? It could be time.
3 the last thing that I recall you touching was the ignition... stretched the wires, check connections and condition of the wires....You'll want to retrace your steps since the running video, maybe you touched or moved something out of place.
Should be something simple ....seemed to run decent in the video....Did you add bad fuel maybe?
  Did you just put on air filters since the video...doesn't sound major mechanical so it's something minor... all in the tracking down. Patience , you'll find the issue.
Offline riverfever
« Reply #101 on: November 20, 2013, 07:27:10 PM »
I do have inline filters. I don't see any sediment in them. I did think the line running to 2 of the carbs looked odd though.  I used new line and it's clear but it had air in it. I'll get a picture of it.
All of the pipes are hot. I will check the wires to the coils but, to be honest, I was planning on upgrading the ignition system but I don't know what to use yet. I just thought it would be a good idea to upgrade to more modern stuff. Need help here.
Offline rb550four
« Reply #102 on: November 20, 2013, 08:00:28 PM »
I have only upgraded a couple of my 550's and 1 500 to the dyna S electronic ignition, makes timing easier, didn't see much if any improvement in power so I didn't upgrade the rest of them.
I also haven t tried  the Dyna coils either, though there has been much discussion on those  items in these forums.
It's old school for me, don't mind a little more time to tune.
There has been recent discussion about inline filters not giving enough flow to the carbs because they make the line lay flat and there isn't enough downward force for decent flow. They do make 90 degree inlines.
Offline goldarrow
  • one day, i'll be an
« Reply #103 on: November 20, 2013, 08:24:31 PM »
Clean the tank real good.  Fuel filter at the petcock is more than enough to keep sediment from clogging up the jets
CB550 K0
Offline riverfever
« Reply #104 on: November 21, 2013, 04:44:57 PM »
As much as I hate to admit this publicly, I actually think it was low on gas. There wasn't much in the tank last night and what was in there was on the right side. Tonight I put more in and it started up. It ran rough but it never died. Cylinders 1, 3, and 4 were hot but 2 was ice cold. I pulled the plug and checked for spark. While the motor ran on 3 cylinders there was no spark at #2. Then there was. Then there wasn't. Very inconsistent. I tried another plug and it produced constant spark. So I don't think I'm dealing with a coil issue or I would expect it to be bad regardless of the new plug. Reinstalled the plug and it fired up and right away I could tell it was running just like it did the other night. Perfectly. Now if I go WOT it wants to fall on it's face a bit but I suspect this is more typical of a 42 year old bike than anything else. So where do I go from here? I suppose I should install new plugs. These plugs don't have much mileage on them at all but when they were run it was with those nasty carbs. Should I start there?
Offline rb550four
« Reply #105 on: November 21, 2013, 05:08:26 PM »
If it were me , I would do the plugs points and condensers,time it and sync it. You are still burning unevenly. That's where I would start . Quick question Are you charging ,is your battery up?
 Low gas...it happens......and ... it's always funny!
Offline riverfever
« Reply #106 on: November 21, 2013, 05:15:33 PM »
OK then the next question is...if I am going to replace points and condensers, should I replace those with a more modern item? If so, what? I have seen the set up from cb750ignition but I know nothing about this. I am planning on vacuum syncing too.
And yes...I did laugh when I peeked in the tank.
Offline rb550four
« Reply #107 on: November 21, 2013, 05:50:51 PM »
  Do you mean the stock 750 set up? What would the benefit be? Still points and condensers on a plate, same timing issues.
Electronic Dyna S set up? easy installation ,set 1 and 4 only, it'll set you back around $130, can't say that I have experienced any great horsepower gain over points system. Don't understand the hype, just seems more expensive to me.
 This  system only controls when it sparks, can't control air/fuel mix like a( brain) electronic fuel delivery system that can adjust everything  to maximize engine output in any range of climate or conditions, spark is it's only job and it can do it, Kinda like Beta and VHS , two different ways to do the same thing. hard to say which was better.
Offline riverfever
« Reply #108 on: November 21, 2013, 06:16:39 PM »
This is what I had seen but don't know if it's truly better than the stock stuff.
http://cb750ignition.com/
Offline rb550four
« Reply #109 on: November 21, 2013, 06:52:52 PM »
This might be a good time for someone like Hondaman to pipe in or any members that have experience with the Pamco product line.                                                              Or PM Hondaman if there is no input here.
Have you searched for prior discussions about this subject? Perhaps , that's the reason folks haven't chimed in yet , they are reluctant to open a can of worms discussion that has been done before. maybe.
Just ran through some threads ,search    pamco ignitions,          lots of feedback , mainly positive, check it out , see what you think.
« Last Edit: November 21, 2013, 06:59:58 PM by rb550four »
Offline riverfever
« Reply #110 on: November 23, 2013, 09:41:48 AM »
Different question here:
I'm going to start the body work on the tank this week and I'm looking for advice on exactly where to apply body filler. What I really would like to know is does a thin coat get applied every where just to fill in small holes that I can't see as easily? I would think so and then sand it down just to where I can see the bare metal coming through again. Also what about the areas at the bottom of the tank where the welds are? Do I try to get that covered and just work slowly with the sanding? Thanks.
Offline riverfever
« Reply #111 on: November 23, 2013, 10:35:28 AM »
Yes, there are some decent dents in this tank. So I'll look to work those first and try to get the whole thing back in shape and then start working the entire tank. Thank you.
Offline rb550four
« Last Edit: November 23, 2013, 05:30:11 PM by rb550four »
Offline riverfever
« Reply #113 on: November 24, 2013, 11:59:39 AM »
Well yesterday I bought some supplies and this morning I started in on it. This is the first time I've ever done any body work so this should be interesting. I'm moving very slowly and building up the layers bit by bit. I started with what I thought would be easier dents. These pics are from about the third application in some areas.
This area by the right of the filler neck really freaks me out but I'm just going to keep adding layers.
Offline riverfever
« Reply #114 on: November 24, 2013, 05:13:41 PM »
Thanks. It's been fun but slow. I feel kind of silly talking about paint schemes right now because the frame looks so ugly with it's paint job but I didn't wanna be that guy who just stripped this bike totally down and built it with no experience and no real direction. All along I told myself that if I could get it looking (overall) how I wanted, that maybe next winter I could pull the motor and paint the frame. Anyways...Hyundai, Jeep and Chevy are using a gray that is gloss but it's really creamy. I'd love to have the headlight bucket, tank, and side covers in that color. Then I'd like the knee dents to be done in gloss black (maybe a pinstripe around the knee dent). I want to use the vintage style tank sticker, and I have an idea in mind for pinstripes on the side covers. Then I want to bob the rear fender and use a smaller tail light and relocate the license plate.
I know prep is really critical but how much will a few coats of sandable primer hide? I keep feeling for transitions or high spots but I never know if I'm being too picky or what?
Offline riverfever
« Reply #115 on: November 25, 2013, 04:19:25 PM »
I got to work on the tank a lot today. Here are some progress pics.
After I took this picture I was a bit frightened.
This took a lot of time. I can safely say that I did not think this job would be this big of an undertaking. I hope I can make this turn out ok.
Offline riverfever
« Reply #116 on: November 27, 2013, 12:35:40 PM »
Here's the progress after today.
I decided to grind all the filler from around the neck off. I just figured it was a larger area to show my lack of experience. I was able to do the other knee dent. I think I'm happy with how thing are going. Hoping someone can answer some questions. I have hammered down the visible metal inside the knee dents. Do I need to apply a thin layer of filler over those areas and sand it again or will sandable primer be able to cover the small dimples? Do I need to bother with putting filler on the rest of the bare metal as long as it is straight? I have a few more areas that need a bit more filler and then I think I'm ready for primer and Guide Coat to really see how bad it is but wanted to ask.
Offline riverfever
« Reply #117 on: November 27, 2013, 01:42:20 PM »
Here's a better shot of the bad side. It is still low where the badge would go so I'll put some more filler there and I also found a little ding at the bottom of the tank.
OK so I'll get more filler, sand paper and some primer tonight. Thank you.
« Last Edit: November 27, 2013, 01:48:29 PM by riverfever »
Offline riverfever
« Reply #118 on: November 27, 2013, 06:21:38 PM »
I don't know. I keep going back and forth. I have thought about keeping the headlight bucket black and painting the tank and side covers a creamy gray and then doing gloss black on the knee dents and using an all white honda wing emblem on the tank. But then I've also thought about doing the stock candy blue color on the tank and side covers, again gloss black on the knee dents and headlight bucket (maybe candy blue on the headlight bucket) and then using the honda emblem that is newer and has a bit of gold in it. I kinda like the idea of using the stock color. Open to suggestions.
Offline riverfever
« Reply #119 on: November 27, 2013, 07:42:02 PM »
The gray on your bike looks incredible but the aluminum triple trees and filler cap are really nice. I also thought about that orange color too. I'd really like a metal flake blue with gloss black. My wife is telling me that we should pay someone to shoot it and the side covers that way. I'd sure like to paint it myself but I also don't want to be disappointed. The tank really could make or break the bike.
Offline riverfever
« Reply #120 on: November 28, 2013, 03:21:33 PM »
I got a little bit of work done on the tank before Thanksgiving dinner was ready. I started off by priming the tank.
Next I started sanding. And sanding. Here you see all the work I have in front of me. No shortage of high spots. I'm learning as I go here and one lesson I learned was that I used way too much primer to paint the tank. It is clogging up the paper.
Then I started applying a very thin layer of filler trying to fill in the low spots.
I pretty much quit for the night. Tomorrow I will use the DA to knock the high ridges down and then switch to hand sanding to even things out.
Big thanks for all of the help/guidance fellas.
Offline riverfever
« Reply #121 on: November 29, 2013, 01:46:26 PM »
More from today's 6 hour work session.
Offline riverfever
« Reply #122 on: November 29, 2013, 01:54:24 PM »
One more.
The leading edge of the knee dents has become much more gradual with the body work nearing completion. I'm still not sure if all the areas I've been messing with are completely flat though.
Offline riverfever
« Reply #123 on: November 30, 2013, 04:56:27 PM »
I pulled another long day today and I think I may be at the point where it may be good enough. It's not perfect but I'm also not a body man. I have a whole new respect for people that can do flawless body work. It's a lot of work. Here's the tank as of an hour ago.
This is the bike after I removed the rear tail light and plate. Next up will be to bob the fender right about where it is here and then install a smaller light and then relocate the plate.
Offline riverfever
« Reply #124 on: November 30, 2013, 08:40:33 PM »
It is. Thank you for the advice you gave. There are still some issues with it. It's not perfect. I really was going to try painting it myself. Little background on me...I have raced bicycles for 20 year until recently when an accident caused a nerve to be pinched at C5 making riding bicycles too painful for me. For the last 6 years I have done self-supported endurance races like the Colorado Trail Race. I was hoping to do Tour Divide next and had already talked to a custom frame builder but that's done now. Now...I ride a fully rigid single speed. Things would probably be different if I rode full suspension but I just can't do it. So tonight I talked to that same frame builder. He does his own paint. He's been following the progress on facebook. He's going to paint the frame and side covers. Now I gotta go back and address a few of the issues.
This is the color blue I'm thinking of.
