Author Topic: Motorcycle Tool Guide  (Read 3490 times)
Offline Einyodeler
  • Midnight bugs taste best!!!
« on: May 19, 2005, 05:51:59 PM »
                                                 Feel free to add your own...
                                                 __________MOTORCYCLE TOOL GUIDE__________
HYDRAULIC BIKE JACK--ingeniously designed tool for flipping bikes onto their sides,usually when you`re alone in the shop.
EIGHT FOOT LONG 2X4--used for levering bike upright after using bike jack.
WIRE WHEEL--cleans rust off old bolts and then throws them somewhere under the workbench at the speed of light.Also removes fingerprints and hard earned guitar calluses in about the time it takes to say"hand me another beer".
DRILL PRESS--a tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room , splattering it across the Ridgid calender hanging on the wall.
OXY ACETYLENE TORCH--used almost entirely for lighting those stale cigarettes you hide in the bottom of your toolbox.
VICE-GRIPS--used to round off bolt heads.If nothing else is available,they can also be used to transfer intense welding heat to the palm of your hand.
ELECTRIC HAND DRILL--normally used for spinning steel Pop Rivets in their holes until you die of old age.
MECHANICS KNIFE--used to open and slice through the contents of cardboard boxes delivered to your front door;works particularly well on cartons containing leathers and bike covers.
E-Z OUT BOLT & STUD EXTRACTOR--a tool that snaps off in bolt holes and is 10 times harder than any known drill bit.
TWO TON HYDRAULIC ENGINE HOIST--a handy tool for testing the tensile strength of ground straps you may have forgotten to disconnect.Almost capable of lifting a Gold Wing off of the floor.
BATTERY ELECTROLYTE TESTER--another handy tool used for transferring sulfuric acid from your bike`s battery to your toolbox after determining that your battery is deader than a  doornail,just like you figured.
HACKSAW--a cutting tool that transforms human energy into a crooked ,unpredictable motion,the more you try to influence it`s course,the more off track you go.
TROUBLE LIGHT--the mechanic`s own tanning booth.Sometimes called a drop light,it is a good source of Vitamin D(the sunshine vitamin)which is usually not found in garages at night.It`s main purpose is to eat 40 watt bulbs like they`re going out of style,more often dark than light it`s name can be somewhat misleading.
AIR COMPRESSOR--a machine that takes energy produced in a coal burning power plant 300 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic Impact Wrench that grips rusty bolts last tightened 35 years ago by someone under the shadow of Mt.Fuji,and rounds them off.
« Last Edit: May 19, 2005, 05:56:30 PM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: Motorcycle Tool Guide
« Reply #1 on: May 25, 2005, 09:55:29 PM »
5 minute epoxy- the only substance that will not harden in any time frame unless it has run away from the place you put it.  Will not harden while being watched or if you have to hold by hand any part being glued.
Arc welder- Will seek out chrome or nice finished surfaces as soon as you lower your helmet, Will not arc if you have moved into some postion that will hurt you tomorrow, unless of course the slag can drip onto exposed skin.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline oldbiker
  • I HATE RAIN
« Reply #2 on: July 20, 2005, 06:37:06 AM »
I always thought a motor-cycle tool guide was a split in the front of the seat!!
Badboy
« Reply #3 on: October 03, 2005, 06:39:19 PM »
A twenty pound sledge hammer, in case all else fails!
« Reply #4 on: October 03, 2005, 07:40:59 PM »
Fire.  Fire cures everything.  and money does to.
Offline Egil
SV: Motorcycle Tool Guide
« Reply #5 on: October 09, 2005, 09:41:43 AM »
Is  it here l go to work  ;D and  stop the fire   ;D
And l get the money ???
Egil.
« Last Edit: October 29, 2005, 12:52:07 AM by Egil »
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
« Reply #6 on: October 09, 2005, 09:10:07 PM »
Egil
Where have you been?  I missed you
quail
Offline Egil
« Reply #7 on: October 10, 2005, 02:57:35 AM »
Thanks.
When my driving carantene stopt ;D(90day`s +/- 1day or 2) my doctor tell my to try working basic 50%   again.
So when l com home after work  there are thing that l have  to do "you now" ;)
 I nearly op and go whit tings back from july-august :).
Egil.
73 de La2vpa.
Egil.
My bike :
bike54
« Reply #8 on: October 10, 2005, 03:38:43 AM »
nice to see you back egil
merv
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #9 on: October 10, 2005, 02:55:12 PM »
HELICOIL KIT - Used to replace stripped out headbolts.  To be used in conjunction with an unsteady hand drill and huge wads of toilet paper.
AMAZING ALUMINUM ATTRACTO-MAGNET(patent pending) - Used to clean all the aluminum shavings that somehow made it past your wads of toilet paper and into the crankcase.
HIGH TEMPERATURE FURNACE - To melt the damn crankcase down into slag when you finally give up trying to take the blasted thing apart.
« Last Edit: October 10, 2005, 02:57:24 PM by DammitDan »
CB750K4
« Reply #10 on: October 11, 2005, 06:19:42 PM »
ALUMINUM foil: to wrap the fuses with so you can turn your wiring harness into a heating elemet in the winter.
Offline Rsnip988
« Reply #11 on: October 24, 2006, 01:01:16 AM »
Brilliant and highly acurate
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
