Author Topic: 750k left side cover  (Read 947 times)
Offline Djfob
« on: October 24, 2013, 12:01:09 PM »
Are the mounting holes the same from 69-78? I'm looking at a joker machine left side cover for sohc. Just confirming it will mount up to my k8.
78 CB750k
Offline Geeto67
  • A grumpy
Re: 750k left side cover
« Reply #1 on: October 24, 2013, 12:07:36 PM »
no.
1969-1976 K is one set of mounts. 1977-78 K is another set and 75-8 F is another, and 77-78 is also different.
There is some interchangiblity ( one side of 77-78F will interchange with 75-76 F but I forget which), but generally there isn't a lot that interchanges back to 69-76 because of the oil tank cap on the right.
The left might work, I would think if it is a custom part it is probably engineered to fit with some...ahem...adjustment.
I just looked on joker machine's site though....why on earth would you want that?
« Last Edit: October 24, 2013, 12:12:03 PM by Geeto67 »
Maintenance Matters Most
« Reply #2 on: October 24, 2013, 12:26:43 PM »
frankenfrankenstuff K8 covers are t!ts.
http://www.fb-stuff.com/
« Reply #3 on: October 24, 2013, 01:29:27 PM »
Yes!  Also K0 oil tank will not accept later K cover, the shape is different.
