Author Topic: cb550 piston kit  (Read 3118 times)
jdhasten
cb550 piston kit
« on: August 29, 2006, 12:57:55 PM »
new here, looking for a 550 big bore kit but, at this point i would settle for the next bore up if i could find a new set of pistons and rings.  '74 cb550
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: cb550 piston kit
« Reply #1 on: August 29, 2006, 02:39:19 PM »
Just my area of expertise unfortunately!
www.classiccycleparts.com
Look for the CB500 Big Bore kit for 555cc.  It's about a 0.5mm overbore on the 550.  $120 for the set of pistons/rings etc.
supersport_CB400F
« Reply #2 on: August 29, 2006, 04:03:56 PM »
I  bought a set of barrels and pistons/rings off ebay for 18.50 USD,  6K miles, perfect  fix for my needs. 400 engine, but I’m sure the same things turns up for a 550. Why pay all that money for the oversize suff? The bike wont go any faster unless you do lots of other work!
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: August 29, 2006, 04:15:04 PM »
I suppose it's peace of mind.  I've had nothing but bad luck with my engines in my 500 and 550.  There's something comforting about having to break in a 30 year old engine all over again.
For $120, you get new pistons, rings, pins, clips and a head gasket.  The 0.5mm overbore is right in Honda specs.  Can't beat the price for the parts.  Granted, if you could find a 6K mile setup from someone you trust, then go for it.
jdhasten
« Reply #4 on: August 30, 2006, 01:27:13 PM »
Thanks for the info. Just wondering though, would the 605 kit with the new sleeves work or am i being too greedy?
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #5 on: August 30, 2006, 01:43:43 PM »
I remember someone on here say that the sleeves in the 550 will bore out to except 750 pistons so the 605 kit should be OK.  Other wise just have the 605 sleeves fitted to your 550 block then bored and honed for the pistons.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
