Author Topic: Regarding Tsubaki Cam Chain master link  (Read 3395 times)
Offline Dimitri13
  • 1974 CB550K
« on: November 06, 2013, 06:06:38 PM »
After having troubles riveting my master link, I decided to do some research, and found that the master link I had was a press-fit, not meant to be riveted. You can tell because the posts of the link are solid and the same color.
I ordered 5 master links from Z1, and one I miraculously got a rivet style master link. You can tell because the ends of the posts have dimples and are a different color.
Refer to the images.
Offline albertaboy
  • No way I'm a
Re: Regarding Tsubaki Cam Chain master link
« Reply #1 on: November 14, 2013, 01:25:21 PM »
Hi
I am not clear. Which one is the best one to get, or easiest to use??  Thanks. Ive got to do this soon.
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
« Reply #2 on: November 14, 2013, 07:47:24 PM »
They are really good, you have to press them on tightly and then insert the clip. The rounded end of the clip needs to be facing the direction of travel
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: November 15, 2013, 01:03:28 AM »
I'm not sure which one is better, albertaboy.
Bobby, the press fit link is not a clip style master link like a drive chain. From what I read, since there is very little lateral movement of the chain, being a press fit link is good enough. The fit is extremely tight and can't even be started by hand.
Offline 74750k4
« Reply #4 on: November 15, 2013, 03:35:44 PM »
Best to use the proper chain link tool to put those together. For accuracy, measure your existing chain links (caliper), that way you know how much to squish the plate on. Otherwise you're guessing. Too little, and it will be too loose. Too much, it's going to bind at that link. Once you dial that in, using your tool, proceed to mushroom the pin SLIGHTLY, without squishing the plates closer.
These go on sale for $39.00, right now they are $89
http://www.cyclegear.com/CycleGear/Accessories/Tools/Multi-Tools/brand/STOCKTON-TOOL-COMPANY/Chain-Breaker-and-Rivet-Tool-Kit/p/36518_00000
« Reply #5 on: November 15, 2013, 05:50:56 PM »
OK. I have used the Tsubaki drive chain links. Quality products! I did not see cam chain. You have received some great advice.
Offline fmctm1sw
« Reply #6 on: November 16, 2013, 07:42:05 AM »
You may have seen some of my posts on this subject.  I either posted them here or the Hondatwins site.  I think there is a guy on Hondatwins that contacted the manufacturer about it too.  My 550 master link is pressed on with no apparent issues.  I'm at around 150 miles on it at this point.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #7 on: November 16, 2013, 01:31:49 PM »
I use the rivot type but you need to take your time and not overdo it. Sorry but I wouldn't trust the press on.
AJK
« Reply #8 on: November 27, 2013, 05:10:55 AM »
Either will work fine. The press fit one i think is the easiest and you can do it with vice grips. Take your time with it and progressively adjust the vice grips working each end at a time to get it squeezed on. Once on, it will NOT come off, so you can sleep easy! To get it off, you will need to grind off the pins (as i have had to in the past).
  When squeezing on, continually check the plate-to-plate width against a neighbor link. Keep squeezing until they have the same widths as the surrounding links.
  I've done both link types with the tsubaki chain. They both work great, but i like the press fit one better. Just a personal choice on this one.
The stake link was a bit more finiky. I used a press pin to get it on, but the pin that I was using wasn't quite the right size, so the job wasn't as neat as i would have liked. I ended up peening the edge of the stake with multi-grips again. I tore the motor down some time later to fix a leaking puck and while i had the rocker cover off, i rechecked the stake and it was as the day i staked it, so all good.
cheers
alex
Offline 74750k4
« Reply #9 on: December 02, 2013, 07:37:18 PM »
WRONG AGAIN!!!  $19.00 now!  Just might need another!
