Author Topic: Pamco plug gaps  (Read 869 times)
Offline gregripko
Pamco plug gaps
« on: November 24, 2013, 09:01:13 PM »
Cb550k 76
What would be the optimal plug gap for the pamco ignition on cb550... What disadvantages would occur if overgapped?
AJK
Re: Pamco plug gaps
« Reply #1 on: November 24, 2013, 11:59:54 PM »
I have a K2 CB750 with a pamco ignition together with the 17-6903 coils (the beefy ones). I'm running 0.035" gaps comfortably & the bike is running great. Pamcopete says that gap is fine for those coils and could possibly be pushed out to 0.040" if one wished (read it on a xs650 website).
  If your running a lesser coil, then probably stick with stock gaps.
Offline gregripko
Re: Pamco plug gaps
« Reply #2 on: November 25, 2013, 12:03:47 AM »
I'm running cb900 coils.... Don't know how they compare to the aftermarket coils
AJK
Re: Pamco plug gaps
« Reply #3 on: November 25, 2013, 12:28:24 AM »
Even though you have a pamco, I'd stick with a stock gap recommended for a cb900 if thats the coils you are using, but perhaps the upper range of what honda recommends for the cb900 plug gap, & try that.
These pages should keep you occupied for a while.
http://forums.sohc4.net/index.php?topic=83840.25
http://forums.sohc4.net/index.php?topic=87411.25
You might also find this page an interesting read.
http://www.xs650.com/forum/showthread.php?t=11670
Re: Pamco plug gaps
« Reply #4 on: November 25, 2013, 02:44:16 AM »
What is the advantage of using bigger gap?
