Author Topic: Valve spring compressor  (Read 3371 times)
Offline mcswny
« on: January 11, 2014, 02:52:17 PM »
Does anyone know if this valve spring compressor will work for our 750s?
I know I could make one but If this will make my life easier Id rather get it.
Thanks!
http://www.ebay.com/itm/111106860674?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Sent from my iPad using Tapatalk
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline ncstatecamp
Re: Valve spring compressor
« Reply #1 on: January 11, 2014, 03:07:22 PM »
I ended up using a large c- clamp with a piece of 1"PVC I carved a channel to remove the retainer. Just pad the end of the c-clamp.
Offline tino montreal
« Reply #2 on: January 11, 2014, 04:05:49 PM »
Cut a small square window out of a 3/4 inch socket with grinder, and use a c clamp.
Offline bj
« Reply #3 on: January 11, 2014, 04:30:17 PM »
Had one and didn't like it. You can't get enough leverage on the clamp to compress the spring and if you try to screw it down, the end that goes on the valve spins. I ended up getting this one http://www.ebay.com/itm/Auto-Motorcycle-Valve-Spring-Compressor-C-Clamp-Service-Kit-ATV-Engine-HeavyDuty-/331038850550?pt=Motors_Automotive_Tools&hash=item4d1373fdf6&vxp=mtr. Add a rubber table leg cap from Home Depot on the valve end. I've used it on several heads and it works great.
CB550K1, CB350K4, CB350K4 race, '81 Passport
Offline mcswny
« Reply #4 on: January 11, 2014, 04:37:02 PM »
Thanks guys looks like I'll be making something myself
1972 CB750 K2
1975 XL250
198 XR80
Offline Bailgang
  • Scott
  • Indiana
« Reply #5 on: January 11, 2014, 11:06:52 PM »
Just the opposite for me, I used an automotive type valve spring compressor like the one the OP posted and it worked great when I was installing pretty stiff kibblewhite valve springs on a 750 head. If anything it was a bit overkill but I had no problem compressing the springs once I had the compressor adjusted right. However that style of valve spring compressor wouldn't work on the head of my 550 and in that case I made up a tool similar to what tino describes along with a c-clamp.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline edwardmorris
  • Youngish
« Reply #6 on: January 12, 2014, 10:30:03 PM »
Thanks!
I usethe same one, worked well on standard and heavy duty springs for me.
Offline setdog
« Reply #7 on: January 13, 2014, 02:56:46 AM »
Have you tried the deep well socket and hammer trick to remove? Worked pretty damn well for me.http://www.dansmc.com/valve.htm
Of course you'll still need the compressor to get them back on.
« Last Edit: January 13, 2014, 02:59:19 AM by setdog »
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
« Reply #8 on: January 13, 2014, 04:30:08 AM »
I found that one too late to try, but sure sounds easy.
Offline ncstatecamp
« Reply #9 on: January 13, 2014, 03:57:07 PM »
I tried one that you borrow from o'reilly's that's similar to that one and I couldn't get it to hold on the springs. Though that looks better designed.
Offline setdog
« Reply #10 on: January 13, 2014, 05:32:18 PM »
On a twin I was having a very hard time getting the tool to set properly on the valve head, I have the bike masters $60 one, so I stuck a golf ball in there against the valve head (chamber side) and it made putting the keepers back in a snap.
The tool was awkward to get seated well and I was concerned about scratching
The valve, golf ball helped to keel the centered, and off the valve.
76 CB 200T. (sold)
Offline mcswny
« Reply #11 on: January 22, 2014, 06:54:25 PM »
I ended up just using one of those quick grip vice grips and a ground down socket. It was free and pretty easy!
1972 CB750 K2
1975 XL250
198 XR80
