Author Topic: 1977 CB550F Cam Shaft and Sprocket Removal - Success!!!!!  (Read 2789 times)
Offline dagersh
    • Photos
« on: February 09, 2014, 07:03:48 AM »
Hi Guys,
I did some searching, but I cannot find any answers.
I am attempting to remove the Cam Shaft from the Engine.  I would like not to break the chain if possible.  Here is where I am:
1.  Both bolts are out of the Sprocket
2.  The Tensioner is as loose as it can get (I checked the tension as I moved the adjuster clockwise and where it stopped the chain has as much free play as it gets)
3.  I am able to lift the shaft on the right side, but I cannot get it to clear the engine case.
4.  I am able to spin the engine and was able to check the Sprocket in different positions to see if I could get some more clearance, but no go....
Here are some pics of where I am now:
As always, any help would be greatly appreciated.
Gersh
« Last Edit: February 09, 2014, 10:21:42 AM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline LesterPiglet
  • 1977 CB550F2
Re: 1977 CB550F Cam Shaft and Sprocket Removal
« Reply #1 on: February 09, 2014, 08:14:14 AM »
Remove the chain from the sprocket first. There will be enough free play in the chain for this.
Offline dagersh
    • Photos
« Reply #2 on: February 09, 2014, 08:42:38 AM »
Lester,
I forgot to mention that I also do not have enough clearance to.remove the chain off the sprocket.  Nor can I get it to disengage from the crank....
Thanks,
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
  • 1977 CB550F2
« Reply #3 on: February 09, 2014, 08:46:40 AM »
Put a screwdriver or something down the rear of the chain tunnel and push the tensioner in.
The shaft should move to the right just enough for the sprocket to come off its seating anyhoo.
« Last Edit: February 09, 2014, 08:51:37 AM by LesterPiglet »
Offline dagersh
    • Photos
« Reply #4 on: February 09, 2014, 09:22:53 AM »
I will give it a go.  Thanks!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1977 CB550F Cam Shaft and Sprocket Removal - Success!!!!!
« Reply #5 on: February 09, 2014, 10:21:01 AM »
Les,
1MM Times THANK YOU!!!!!!  So easy and worked a charm.  Do they mention this in the Honda Manual?  Clymer, as always, leaves a lot to be desired!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
  • 1977 CB550F2
« Reply #6 on: February 09, 2014, 10:26:27 AM »
I never seen it mentioned but I don't have a Honda manual. It just seemed like something I should try. Its also useful when replacing the cam.
« Last Edit: February 09, 2014, 10:28:25 AM by LesterPiglet »
Offline dagersh
    • Photos
« Reply #7 on: February 09, 2014, 10:49:41 AM »
Les,
If it is OK with you I would like to do a pictorial for the FAQ section.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
  • 1977 CB550F2
« Reply #8 on: February 09, 2014, 11:50:59 AM »
 :) Who am I  to disagree? Good idea.
« Reply #9 on: February 09, 2014, 11:53:03 AM »
the sprockets without that black plastic guide are easier to work with aswell.
Offline jonda500
« Reply #10 on: February 09, 2014, 09:54:09 PM »
My $200 cb500 has one of them - it converted itself into one - I found all the little pieces of what used to be black plastic guide in the sump!
A starter clutch thread:
« Reply #11 on: February 10, 2014, 12:29:02 AM »
i made one once when i found one cracking,i just knocked it all of.
  • 1977 CB550F2
« Reply #12 on: February 10, 2014, 03:50:06 AM »
I removed mine as well. Specially lightened for racing.  :P I guess it's to cut down on noise originally?
