Author Topic: 1975 550 tuning.  (Read 623 times)
Offline brianincc
1975 550 tuning.
« on: February 17, 2014, 03:20:49 PM »
Quick question. I recently rebuilt my carbs and went through the 3000 mile tune up and things were running pretty well. I decided to pull my plugs and see how they looked and I was definitely running rich. I measured the gap on the old plugs and they were at about .025 I bought new  ngkd7es plugs and gapped them to .060.  I had a difficult time getting it started after the plug change but once it was on the road it ran better than ever. Absolutely no hesitation and pulled hard. I only ran it a few miles and noticed while idling I was getting a little smoke out of the exhaust that I never had before.
 BIke is very hard to start and if I give it any gas at all it wont start.
So I threw the old plugs back in and it fires right off, no smoke but doesn't pull as hard and the little hesitation is back.
 With the old plugs I was running about 2 turns out on the mixture screws but was getting some popping when coming off the throttle hard and had a small hesitation when getting on the throttle.  I went to one turn and the popping went away but the hesitation persists. I do have a couple of holes in my exhaust that could be causing the backfiring. Sorry for the novel. Any ideas are appreciated.
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
Re: 1975 550 tuning.
« Reply #1 on: February 17, 2014, 07:10:44 PM »
I'm no expert, but my book says to gap the plugs at .024-.028
                       Doug
Offline brianincc
« Reply #2 on: February 17, 2014, 07:32:41 PM »
And you would be correct. That's what I get for using  google as my service manual.
Everything is good now.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: February 17, 2014, 07:35:31 PM »
0.024" = 0.6mm
Offline Rgconner
« Reply #4 on: February 18, 2014, 07:24:13 AM »
If you upgrade the ignition system to handle higher voltage coils you can do a bigger spark.
Tears up the plugs faster, but you definitely get that hard pull without the hard starting.
1975 CB550K aka "Grease Monkey"
