SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1976 550 f master cylinder
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1976 550 f master cylinder (Read 652 times)
anji mehra
Full Member
on:
March 10, 2014, 11:07:14 PM »
Hi
Just recieved the kit for the master cylinder, but am totally foxed as to how to get the rubber piston on to the shaft over the two large Dias?
. Can't imagine that it would stretch that much
Thanks
Anji
Logged
dave500
Really Old Timer ...
WHAT?no gravy?
Re: 1976 550 f master cylinder
Reply #1 on:
March 11, 2014, 01:07:43 AM »
wet it with brake fluid,its seems wrong and abusive but it does go over.
Logged
Dr. Noisewater
Hot Shot
Reply #2 on:
March 11, 2014, 06:36:34 AM »
Yeah lube it with some fluid, and don't bend those fins when slipping it over.
Logged
anji mehra
Full Member
Reply #3 on:
March 12, 2014, 03:19:43 AM »
Thanks Dr & Dave. Got it over, but no fluid being pumped out after assembly. Rechecked assembly & it seems OK. Any suggestions ?
Thanks
Anji
Logged
dave500
WHAT?no gravy?
Reply #4 on:
March 12, 2014, 03:42:42 AM »
are you familiar with the bleeding process?squeeze the brake then open the bleed screw,close bleed screw then release brake then squeese it again then open bleed screw then over and over untill it works?
Logged
anji mehra
Full Member
Reply #5 on:
March 12, 2014, 04:59:31 AM »
http://
Yes, Dave am familiar with the bleeding process. Problem is that no fluid coming out of the master cylinder to the calipers. Maybe an air lock. Will reassemble the cylinder & see
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
