Author Topic: Question for the painters  (Read 1151 times)
« on: March 26, 2014, 03:47:07 PM »
I use a wheel silver rattle can paint by PlastiKote on one frame. At different points during application it will burp out a bunch of fleck. The can is always well shaken, before & during the job. The frame was primed first and the surface is always clean. Part of the time the coverage is perfect, then will spew out this fleck.
I've used this paint for four years and I always experience the same issue. This fleck sits on the surface and I just remove it with a soft scotchbrite pad. The paint is quite unaffected. This is a race bike not a show piece so I'm able to touch it up regularly.
It's likely the applicator... any ideas what I'm doing wrong?  ;D
Offline brooze72
Re: Question for the painters
« Reply #1 on: March 26, 2014, 04:28:32 PM »
Yea likely the applicator... By that I mean the nozzle, rattle cans tend to drip/clog at the orifice after using it for awhile.  Change out the nozzle or even give it a wipe with some thinner on a rag periodically.
1972 CB500K1 - restored rider
1981 CB650C - new project
« Reply #2 on: March 26, 2014, 05:28:24 PM »
It was a brand new can, but any other I've used was the same. More likely the other applicator Bruce!
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: March 26, 2014, 05:32:02 PM »
I don't remember what brands in particular but it has happened to me with lesser well known cans. I don't use plastikote.
« Reply #4 on: March 26, 2014, 05:54:04 PM »
I've used this paint before and not had any issues. It's this silver wheels stuff. I like the colour but probably should have changed brands.
  • 1977 CB550F2
« Reply #5 on: March 26, 2014, 06:36:22 PM »
Actually I have used Steel Wheels in the past few years but I don't know if was Plastikote. It turned out great.
Offline 750K
« Reply #6 on: March 26, 2014, 07:58:40 PM »
Sometimes spray cans will have been sitting on the shelf or warehouse for ages, you will fine the paint solids will settle to the bottom which is where the tube that feeds the valve and nozzle. You might think its shaken well but there's still some sediment that isn't in the mix, cleaning off the nozzle periodically will help as well.
77 Cb750, 78 Kz1000
Offline krusty
« Reply #7 on: March 26, 2014, 11:26:55 PM »
Two things I can think of here.
One is, are you keeping the nozzle fully depressed all the time?
The other is a suggestion. Shake the can well, then after that stand it in a pot of freshly boiled water for a few (3-4) minutes then shake well again.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #8 on: March 27, 2014, 03:20:57 AM »
Boiled water? Like, 200+ degrees?
Call me a nancy boy, but I'd personally aim a little lower to warm up a thin metal cylinder pressurized with propane. I do the same to help rattle cans flow, with water as hot as I can get from the tap, closer to 140 I think.
I have a motorcycle problem.
