Author Topic: Snag in GL650 rebuild. Look at this wear where the rocker shafts go  (Read 849 times)
Offline fmctm1sw
Everything was going smoothly.  Got the crank and pistons back in.  Oil pump was back in and primed and as I'm about to put the rocker shafts back in I see this.  The surfaces are cratered, one really bad.  I thought it was kind of strange since this is not a rotating part.  There is a bolt that fits in the middle of the shaft to keep it from rotating.  What would you do about this?  There is another engine block on ebay but the seller didn't answer my request to take pictures of this specific area.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline raymond10078
  • Just learnin' as I go . . . .
Re: Snag in GL650 rebuild. Look at this wear where the rocker shafts go
« Reply #1 on: April 07, 2014, 07:39:57 PM »
The bottom pic does not look like wear - but a casting flaw - looks like it has been there since it was new.  Most likely no problem.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
