Author Topic: Help! After Market Pistons and Rings!  (Read 730 times)
Offline Joemetal861
« on: April 03, 2014, 06:26:01 PM »
 Hey guys,
I got the ol' 1978 Honda CB750k all tore down and engine apart. Found the culprit for blow by and low compression, a chip in the piston. I want to bore the cylinders out and replace all the pistons and rings instead of just trying to hone one cylinder.
I was hoping to bore it .25mm over or a 1st over piston kit. The honda shop didnt yield results, so does anybody know a good source were i can find this piston kit. I figured you guys would know a trustworthy company.
Please help!
Joe
Offline Garage_guy_chris
Re: Help! After Market Pistons and Rings!
« Reply #1 on: April 03, 2014, 07:06:05 PM »
if you want to go big bore, the ebay cruzinimage 836cc kits are hard to beat for $120. Lots of positive reviews on here. Only disadvantage is the cost to bore from 750 to 836. its multiple passes and thus costs more from just going .50 or 1.00 over
http://www.ebay.com/itm/69-77-HONDA-CB750K-836cc-BIGBORE-PISTON-KIT-W-GASKET-/141133488874?pt=Motorcycles_Parts_Accessories&hash=item20dc3622ea&vxp=mtr
otherwise the other good deal that comes to mind is the Cycle X .50 or 1.00 over kit for $199
http://www.cyclexchange.net/Engine%20Parts%20Page%20%28Non-Cafe%29.htm
(at the bottom)
Offline Joemetal861
« Reply #2 on: April 03, 2014, 08:22:02 PM »
how does it work if you get the sleeves, do they just press in? and also if i were to go with the bigger kit, wouldnt i have to beef up the cam and valve springs?
« Reply #3 on: April 03, 2014, 09:07:28 PM »
No re-sleeving needed up to 849
Offline cakey
  • 5% recipe and 95% process
« Reply #4 on: April 04, 2014, 12:14:20 AM »
I got my .50 oversize kit from David Silvers USA. Didn't come with the circlips for the wrist pins though, had to get separately. I was told by my machine shop that if I was going to bore out it would be best to go at least .50 oversize if the cylinders were out of round.
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
