Author Topic: Swing arm bushing, cap, dust seal etc.  (Read 3089 times)
Offline mcswny
« on: April 14, 2014, 07:08:09 AM »
I ordered some new Bronze swing arm bushings and plan to install this weekend. Should I plan on getting the other bits that hold them in? Numbers 14, 10, and 13 on the fiche provided? Or is it not necessary?
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Re: Swing arm bushing, cap, dust seal etc.
« Reply #1 on: April 14, 2014, 07:34:23 AM »
You could reuse old ones - or if your new bushing is the flange type, not use them at all.
Offline mcswny
« Reply #2 on: April 14, 2014, 07:36:04 AM »
I got the non-Flange bushings for my K2. But can you use the flanged ones on a K2 without any additional machining?
And is there a quality/longevity difference between he flanged and non flanged?
1972 CB750 K2
1975 XL250
198 XR80
« Reply #3 on: April 14, 2014, 07:40:53 AM »
I used flanged bushings on F arm in K3 frame - the dimension was the same for all of them - there was little too much play between the frame and swing arm, so I used washers and after tightening it is perfect.
Lot of it depends on bushing's flange, they are all made within some tolerances.  It all goes together with some play - tightening the central bolt will eliminate the play, that's how it was designed, but the play should be minimal.
Offline Schnell
« Reply #4 on: April 14, 2014, 08:24:37 AM »
10 and 13 will probably be reuseable, 14 will deteriorate upon removal. It's a felt dust seal. You could make your own.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline mcswny
« Reply #5 on: April 14, 2014, 08:32:59 AM »
Thanks for the help guys.
1972 CB750 K2
1975 XL250
198 XR80
Offline Schnell
« Reply #6 on: April 14, 2014, 08:36:52 AM »
If you find part #10 unusable, I can mail you my old ones because I switched to the top hat style bushings and didn't need that part.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline mcswny
« Reply #7 on: April 14, 2014, 08:44:34 AM »
Thanks Frank, I ordered the non-flange ones last night. However, I want the flanged ones out of simplicity sake. So I emailed to see if I can switch my order, if it doesnt go through and I need the felts, I'll PM you. Thanks.
tim
1972 CB750 K2
1975 XL250
198 XR80
Offline mcswny
« Reply #8 on: April 14, 2014, 03:54:13 PM »
Ooof this may be a stupid question but I've been searching and I can't seem to find the answer (I've only had 1 beverage I swear!) But do you have to take the exhaust off to remove the swing arm (cb750K2)
1972 CB750 K2
1975 XL250
198 XR80
Offline Schnell
« Reply #9 on: April 14, 2014, 04:06:21 PM »
I didn't, but I don't have original mufflers. Mine are low and out of the way enough. Original exhaust would probably be in the way. To reinstall the swing arm, I had to get my head under the rear fender. I had to remove the rear shocks. Maybe if your bike is up on a lift, you can work from underneath.
« Last Edit: April 14, 2014, 04:11:55 PM by Schnell »
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline mcswny
« Reply #10 on: April 14, 2014, 04:35:48 PM »
I have a lift, but I also have HM300s so I'll probably just take the exhaust off to make it a bit easier.
1972 CB750 K2
1975 XL250
198 XR80
Offline mcswny
« Reply #11 on: April 14, 2014, 07:53:57 PM »
Hey 70CB750, you jus use regular old HW washers? Just want to pick some up in case there's some play. Any particular thickness?
Got my swing arm off and cleaned tonight. Getting the old bushings off is next (fun!). And the new bushings should be here Friday. Hopefully riding by this weekend.
1972 CB750 K2
1975 XL250
198 XR80
« Reply #12 on: April 15, 2014, 03:58:28 AM »
I have a bin full of washers, I went through few till it felt right.  I wanted the swingarm to slide in with minimum play - not to force it in.
Offline Schnell
« Reply #13 on: April 15, 2014, 05:04:49 AM »
Loosening the nuts that hold the foot pegs on (is that the rear motor mount too?) eased the installation for me.
I would advise the purchase of the flanged bushings because of the ease of installation. Just bang them in until they seat. With the plain unflanged ones, you have to get them in to a specific depth. Even with heating the swing arm and freezing the bushings, I had to use a 4lb hammer to get the bushings in. I can't imagine having to set them to a certain depth. What happens if one goes in too far?
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #14 on: April 15, 2014, 05:10:29 AM »
Here is an easy way to do it:
Offline mcswny
« Reply #15 on: April 15, 2014, 05:54:55 AM »
I ended up getting the flanged ones, which is good because the felt washers are toast. I got everything off last night. And am going to give taking out the old bushings a go tonight. Getting the depth right in the non flanged ones was what I was worried about
1972 CB750 K2
1975 XL250
198 XR80
Offline mcswny
« Reply #16 on: April 15, 2014, 05:55:17 AM »
Good idea, thanks!
1972 CB750 K2
1975 XL250
198 XR80
Offline slikwilli420
  • Master of Disaster
« Reply #17 on: April 16, 2014, 08:56:42 AM »
Im using a repro Dresda swingarm and noticed that with cups/seals, it is way too tight in the frame. My arm does have the flanged bronze bushings. Is there no concern about leaving those dust caps off with dust/dirt/road grime? If I can just space them on either side evenly to get the slack out, that would be much easier than having dust cups made or finding a replacement that works properly.
Offline mcswny
« Reply #18 on: April 16, 2014, 05:55:35 PM »
I'm sorry, I'm not the best to help you with this probably. Maybe someone else can chime in?
1972 CB750 K2
1975 XL250
198 XR80
Offline mcswny
« Reply #19 on: April 18, 2014, 08:11:10 PM »
So when I was installing my collared ones I noticed there is a little ridge on the inside of the swing arm which I assume could catch and seat the non-collared bushings at their correct depth so there's no 4lb hammer guess work.
I had to have my fiancé hold the swing arm as I wailed on it with my rubber mallet.
1972 CB750 K2
1975 XL250
198 XR80
