Author Topic: CB550F Engine Swap  (Read 957 times)
Offline jackudig
CB550F Engine Swap
« on: April 15, 2014, 06:31:19 AM »
Since my engine needs work, can I replace it with a used K model engine?  Will it bolt right in?
Thanks.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: CB550F Engine Swap
« Reply #1 on: April 15, 2014, 08:51:07 AM »
Yep same engine, different carbs and exhaust is about it. What kind of work does your F engine need? And how do you know the K engine will be any better?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: April 15, 2014, 09:00:31 AM »
Even the carbs are basically the same as long as the K donor is a '74-'76.
The 77-78 K's used completely different carbs (PD series), but any 550 carbs will work on a 77-78K motor as long as you have the intake manifolds that match the carbs you plan to use. You may need to play with the jetting though, so I would recommend using the carbs that match the engine.
Offline Tews19
  • I am no
« Reply #3 on: April 15, 2014, 09:10:44 AM »
I always thought the F meant FAST! K meant Kupcake...... hmmmmm
1970 Honda CB750 survivor.
Offline jackudig
« Reply #4 on: April 15, 2014, 11:20:45 AM »
Compression is low on some cylinders.  138 160 138 148.  Pressure went up with oil in the cylinders.  I read the exhaust pipe temps ( cheap infared gun ) after shutdown and #1 cyl was about 100 degress cooler than the rest.  41000 miles and some oil leaks.  It seems to run alright and starts easily.
Thought if I found a decent engine K or F I could go through it and swap it out while still riding until that point in time.
Offline Jimsun
« Reply #5 on: April 15, 2014, 12:00:16 PM »
If those readings were before you put in oil, then those are some very nice numbers. My readings were 135/130/140/130 or something along that range from cyl1 to 4 respectively. The lower temp can be fixed by cleaning or re building the carbs.
74 cb550
Offline Tews19
  • I am no
« Reply #6 on: April 15, 2014, 03:13:02 PM »
Those numbers are pretty nice if the bike sat for a while.
Offline jackudig
« Reply #7 on: April 16, 2014, 05:43:40 AM »
Thanks for the input.  Maybe I worry too much.  You know how parents are with there own kids.
Offline lucky
« Reply #8 on: April 17, 2014, 12:51:57 PM »
They will not interchange!
Completely different design.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #9 on: April 17, 2014, 12:57:05 PM »
The CB550 SOHC4 K and F model engines won't interchange? That's a load of BS a mile high Lucky.  >:( We put up with a lot of your quirkyness and that's fine, the board has an entertainment value as much as an informative value. But when you're wrong you are just plain wrong. And spreading bad information is just bad news for the board and it's members. All part numbers are the same for both engines, except carburetors and exhaust systems. I have both.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Bankerdanny
« Reply #10 on: April 18, 2014, 09:46:08 AM »
I'm not sure what you mean Lucky. The carbs on my '74K and '76F are externally identical, including the linkages and manifolds. I know the model numbers and jettings are slightly different, but physically they should interchange fine.
The PD's on the '77-'78k's are obviously completely different with different throttle cable and choke setups. But the engines and heads are the same, so as long as you bring the manifolds, airbox, and throttle and choke cable setup with you, they should bolt right up to an earlier engine.
