Author Topic: What type of grease? question.  (Read 1787 times)
Offline grcamna2
« on: April 15, 2014, 06:46:05 PM »
I have this little tiny yellow 77' NC50 Express fork w/ basic spring struts(no oil) for front suspension.
The Factory service manual says 'grease' but doesn't specify the type.I want to lube these little struts so they won't wear out prematurely. I was considering using wheel bearing grease but thought it might be a little too stiff,(although I'm 30 lbs. over the max weight of the bike  ::) )or I was thinking of using some red Valvoline chassis grease. Do any of you members(anybody ever lubed the forks on one of these in a dealership you've worked at before ?)here have any other recommendations for grease ?
75' CB400F/'bunch o' parts'
Offline grcamna2
Re: What type of grease? question.
« Reply #1 on: April 17, 2014, 07:28:41 PM »
bump
Offline krusty
« Reply #2 on: April 18, 2014, 05:51:27 AM »
I've used waterproof boat trailer bearing grease in front suspension linkages. General purpose grease should be ok.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline 750cafe
« Reply #3 on: April 18, 2014, 07:14:29 AM »
I use synthetic grease on any/all grease-able parts of a motorbike. Only the best will do for my babies.  ;)
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline grcamna2
« Reply #4 on: April 18, 2014, 08:10:16 AM »
Eric
Eric,
I'm now thinking about synthetic wheel bearing grease,have you used any of that before ?
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #5 on: April 20, 2014, 05:51:15 AM »
In the Honda Common Service Manual, unless it has a symbol next to the word grease (like an M, MP, or S) the specified grease is a lithium based multi-purpose NGLI #2 grease.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline Peterengland
« Reply #6 on: April 20, 2014, 07:02:26 AM »
In England it is called copperslip and we tend to use this and expander grease on high temp parts
Offline grcamna2
« Reply #7 on: April 20, 2014, 09:27:07 AM »
Peter,
That "copperslip" you mention that you there in England use,what is it similar to here in the US ? does it have graphite or some type of anti friction material added ?
I'm just trying to understand that term because it's new to me  :)
I'll probably just end up using the best grease I can find for this application.I purchased this tiny cycle from a man who owned it in NE MO. and there is a very fine dust up there(almost like powder)and it got into everything and wore the parts prematurely;front fork slider bores and sliders,brake cams at the hub,engine,etc.
Lots of blowing winds up there to drive this stuff inside the surfaces.
I need to replace parts like the forks,etc. & don't want to have to do it again.  ::)
« Reply #8 on: April 20, 2014, 10:34:06 AM »
Copperslip grease is basically a hi temp copper based anti seize. You can buy it here as a copper based anti seize.
Offline grcamna2
« Reply #9 on: April 20, 2014, 12:01:17 PM »
Thanks Bobby
Offline 750cafe
« Reply #10 on: April 21, 2014, 11:31:27 AM »
Eric
Eric,
Actually, I remove the covers from the "sealed" wheel bearings and remove as much of the stock grease as possible and then
re-pack them with synthetic grease and replace the cover on all of my bikes. Less rolling resistance.   ;)
Eric
Offline grcamna2
« Reply #11 on: April 21, 2014, 11:55:15 AM »
I appreciate that tip Eric and I'm thinking it's a smart way to get the most life out of your bearings.Do you do it on new ones only ?
Offline 750cafe
« Reply #12 on: April 25, 2014, 12:08:40 AM »
All of them. As long as they are still smooth and not worn out.
Eric
Offline LesterPiglet
  • 1977 CB550F2
« Reply #13 on: April 25, 2014, 01:28:34 AM »
RE Copaslip/copperslip. Don't use this on any bearings as particles of copper will coat the bearings and f*ck them up. I only use it on bolts/nuts/studs and the like.
Offline grcamna2
« Reply #14 on: April 25, 2014, 04:25:17 AM »
Thanks Man.
