Author Topic: Carb cleaning with Simple Green  (Read 7292 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: April 23, 2014, 07:26:08 PM »
Im,considering cleaning my carbs with true green...can I clean the whole rack by putting it in a container of the stuff? I plan on removing bowls float ect but would like to dip the whole rack in there.
Sent from my PC36100 using Tapatalk 2
« Last Edit: April 23, 2014, 09:08:18 PM by Sdsbassist »
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline grcamna2
Re: Carb cleaning with True Green
« Reply #1 on: April 23, 2014, 07:49:43 PM »
Is that 'True Green' similar to 'Simple green' ? or more powerful ? I'd remove the rubber parts anyway...
75' CB400F/'bunch o' parts'
Offline Jimsun
« Reply #2 on: April 23, 2014, 07:50:43 PM »
Have you heard of pinesol?
74 cb550
« Reply #3 on: April 23, 2014, 07:50:55 PM »
Isn't true green a lawn fertilizer product?!
Offline harisuluv
« Reply #4 on: April 23, 2014, 07:56:07 PM »
From what I recall you have already had them off and on around five or more times?  Might want to consider taking them apart and doing things for the last time.
Last time I saw you had pulled the pilots and had the bike running good again?  Also, how did you resolve the broken off accelerator pump nozzle?
Never heard of True green, if you mean simple green, then it's ok but make sure to use simple green HD (which is actually purple) or else you will discolor (potentially) your carbs.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #5 on: April 23, 2014, 09:07:53 PM »
Simple green yes.
I bought another set of carbs local. Its running alright, been commuting with it until by petcock crapped out. So I have vb one of those and an airbox in the mail, so I thought I was clean the outside as well...
Id read some threads that true green does a nice job cleaning without tarnishing...harrisluv...thoughts were while I couldnt ride anyways I would take them off again, do a deeper cleaning, resolve my accell pump issue then ride again for the rest of the summer :))
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Carb cleaning with Simple Green
« Reply #6 on: April 23, 2014, 09:10:22 PM »
 I have heard of it, yes. Did you soak those? They look nice!
Gus, Austin, MN.
« Reply #7 on: April 23, 2014, 09:10:54 PM »
Don't use pine sol. It's acidic and will damage your carbs.....
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #8 on: April 23, 2014, 09:36:19 PM »
What are your thoughts on the simple green?
Gus, Austin, MN.
« Reply #9 on: April 23, 2014, 10:07:30 PM »
Simple green and carb cleaner are preferred...
Offline bjbuchanan
« Reply #10 on: April 23, 2014, 10:18:57 PM »
I use simple green diluted to 50% and bring it to a rolling boil on the stove. It totally cleans the funkiest crap right up without needing a prolonged soak. Makes the kitchen smell better than carb cleaner too
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #11 on: April 24, 2014, 04:37:15 AM »
take off all the rubber?
Gus, Austin, MN.
Offline grcamna2
« Reply #12 on: April 24, 2014, 05:09:58 AM »
How long do you leave'em on the stove bjbuchanan ?
« Reply #13 on: April 24, 2014, 05:13:04 AM »
I like my carbs "well done".   They run better   ;D
Offline grcamna2
« Reply #14 on: April 24, 2014, 05:13:56 AM »
I would remove any rubber parts that you think are still salvageable,but most likely you'll be replacing the rubber w/ Honda seal kits? if they're available. I wonder what harisuluv recommends about plastic parts ?
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #15 on: April 24, 2014, 05:44:58 AM »
2 years ago I used simple green on SL175 carbs that had been sitiing for 20+ years. Mind you it took a "few" days to soften up the barnacles, but I did get that bike running well. So Simple Green does indeed work well.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline 750K
« Reply #16 on: April 24, 2014, 01:14:37 PM »
+1 to that, I did mine on the bbq in a big enamel canning pot. Those canning pots fit a full rack of carbs and they come with a rack that sits on the bottom of the pot, works wonders, I pull the rack every 20-30 mins and rinse then re dunk till its clean.
77 Cb750, 78 Kz1000
Offline grcamna2
« Reply #17 on: April 24, 2014, 03:44:18 PM »
I appreciate this post 750K;did you actually bring them to a rolling boil for 20-30 mins. each time ? I hope your wife didn't scalp you for using her canning pot  :o  ::)
Offline bjbuchanan
« Reply #18 on: April 24, 2014, 04:01:14 PM »
I left each carb in for about 10 minutes and cleaned it up after I took it out. Re dipped after cleaning and blowing it out. Takes about an hour of busy work overall, maybe a little more.
Offline 750K
« Reply #19 on: April 25, 2014, 11:51:40 PM »
Pretty much, it didn't really hit the point of boiling but it was plenty hot enough. I strung some bailing wire from carb no.1 to no.4 to use as a handle I could raise and lower the carb rack without burning my hand.
I made sure it was ok with my wife, haha. She's all for the resurrection of old Japanese motos, these carbs were off the 78 kz1000 I picked up. It hadent run in about 17 years, defeninatly needed a thourogh cleaning.
77 Cb750, 78 Kz1000
Offline grcamna2
« Reply #20 on: April 26, 2014, 04:26:18 AM »
I've got a gal. of the purple color Simple Green(HD?) but haven't used it on anything yet,is it stronger than the Simple 'Green' standard color ? does it make a green color on your carbs. harisuluv  ???  :o
Hey,is this Simple Green 'heat treatment' lot's better than many cans of Gumout and little brushes and scrapers ?
« Last Edit: April 26, 2014, 06:28:04 PM by grcamna2 »
Offline bjbuchanan
« Reply #21 on: April 26, 2014, 05:58:46 PM »
The simple green works well and isn't toxic like the gumout, a plus. Does plenty of work for you too
I have used most of the degreasers. Purple power works well but I just don't like it, more of a personal thing. They are good degreasers, I prefer how the simple green works. The purple power WILL discolor aluminum fast if left sitting tho
Offline grcamna2
« Reply #22 on: April 26, 2014, 06:29:39 PM »
I've usually only used Gumout,but I can convert to Simple Green if it's more effective.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #23 on: April 27, 2014, 08:10:30 AM »
I used the simple green with syringe trick to clean my PD internals and it was slick...only thing it didnt do was choke out my brain cells like the other cleaners :)
Gus, Austin, MN.
Offline grasscutter
  • Love the CB650.
« Reply #24 on: April 27, 2014, 12:25:35 PM »
Throwing a whole rack of carbs in a boiling pot of Simple Green, rinsing them off with water, re-installing on your bike and expecting them to work, is not going to happen.
No matter what cleaner you prefer to use,  all the ports, passages, jets, etc. need blown out.  Using either carb cleaner and/or compressed air.  Otherwise you've dissolved the gunk with the simple green, but the gunk is still sitting in your carb, until its blown out.
New gaskets and o-rings are also to be used.  *obviously*
Hoping newbies don't read this thread and assume you can dunk a whole rack in some Simple Green and gunked up carbs are magically transformed!!
Come on!  We're burning daylight!
