Author Topic: Assembly lube.  (Read 931 times)
Offline 123mclaren
Assembly lube.
« on: April 26, 2014, 08:59:57 PM »
Assembling complete motor. Case up. I have a can of bel-ray assembly lube, greyish moly stuff.  Can I use that for bearing and journals on all surfaces or do I need to use the red paste stuff?  Motor will prolly sit for 1-2 weeks, maybe oil is okay?
Thanks
Re: Assembly lube.
« Reply #1 on: April 27, 2014, 05:56:42 AM »
I would use Red Line, Spectro or Torco assembly lube....the Bel Ray is to pasty and does not break down easily.
Offline thirsty 1
Re: Assembly lube.
« Reply #2 on: April 27, 2014, 06:19:34 AM »
I've been using this for over 20 years and hundreds of engines. It's good stuff!
http://www.lubriplate.com/Products/Automotive-Lubricants-Motor-Oils/Lubriplate-No-105-Motor-Assembly-Grease.aspx
