Author Topic: Bought 3 Pinned Style 550 Rocker Covers, Cracks in 2 of Them! Worth Welding?  (Read 854 times)
Offline Trad
Hey Guys,
I ended up buying 3 of the pinned cb550 rocker covers. Out of the three one had no cracks, which I will be using. One had a crack by a tappet cover which broke off when I applied minimal pressure (Good rocker shafts at least) and I have one that is in the best shape but it has a crack around one of the locating dowel recesses.
Would anyone bother repairing this? I could have it welded but the crack goes through the mating surface. I really don't want the mating surface welded for obvious reasons. I just know from first hand experience these are becoming harder and harder to source. It's just a shame as this cover is so mint.
« Last Edit: June 26, 2014, 12:44:33 PM by Trad »
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Trad
Ya, it broke off.  :P
Offline lucky
They can be welded by someone that knows what they are doing.
TIG welded to keep distortion to a minimum. 4043 filler wire.
Check on a flat surface when finished.
