Author Topic: Help me identify this wheel... 75 750F  (Read 749 times)
Offline madScientist
« on: July 12, 2014, 06:13:00 AM »
I friend of mine recently purchased a 75 750F which admittedly I am not intimately familiar with. However when looking at it this rear wheel does not look as though it belongs on an F and was hoping ya'll could help me identify it.
The rotor side has 4 bolts (not studs) holding the rotor to the wheel. The rotor looks to be the proper size for an F but the hub looks kind of small to me. The sprocket has a 36 tooth which doesn't mean to much as I know that can be swapped. The tire is WAY too skinny but it could be an undersized tire. I believe the sprocket carrier has 6 bolts on it.
Here are pictures...
Rotor side:
Sprocket side:
Looking down on sprocket side:
Rotor side looking down:
Thanks again guys!
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline goldarrow
  • one day, i'll be an
Re: Help me identify this wheel... 75 750F
« Reply #1 on: July 12, 2014, 06:18:07 AM »
My best guess is yami wheel
CB550 K0
« Reply #2 on: July 12, 2014, 06:35:10 AM »
550 wheel,  could be...
« Reply #3 on: July 12, 2014, 11:32:04 AM »
Are we sure it's a 75?
That is not a stock 75 rear caliper. Is that perhaps a 77/78 caliper? They use different gearing/sprockets too.
Offline Old Scrambler
« Reply #4 on: July 12, 2014, 11:43:59 AM »
No ID necessary................take it off of the bike before something BAD happens.  Then check the motor to confirm it is the original.........not what I suspect is a 77-78 replacement.........needing a wheel change to align the sprockets.  The stock wheel for a 75-76 F-model is available..........but you will have to pay for fighting the mosquitoes at my friends salvage yard. ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline goldarrow
« Reply #5 on: July 12, 2014, 12:07:34 PM »
The rotor design looks like either yamaha or Suzuki.
CB550 K0
« Reply #6 on: July 13, 2014, 12:30:16 PM »
Thanks guys. I thought the caliper looked wrong as well and I'd never seen a 750 rotor with just 4 bolts...I recommended he not ride on the wheel.
I thought it might be a 550 wheel or even a Yamaha wheel. The hub looked bent on it too. His thought was he'd get a new hub which I told him to not even worry about...just buy the proper wheel and be done with it.
Much appreciated for your input!
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
