Author Topic: huge oil leak!  (Read 1201 times)
Offline letutt
huge oil leak!
« on: August 03, 2014, 03:55:12 PM »
I am dumping oil all over the place.  Drive side, cb550.  Please help!
Offline goldarrow
  • one day, i'll be an
Re: huge oil leak!
« Reply #1 on: August 03, 2014, 04:03:45 PM »
Is drive side the sprocket side or clutch side?
CB550 K0
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
Re: huge oil leak!
« Reply #2 on: August 03, 2014, 06:07:32 PM »
I imagine drive = chain?
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline rb550four
Re: huge oil leak!
« Reply #3 on: August 03, 2014, 06:22:27 PM »
Do you mean leaks when parked or running?
Pull the shifter off, remove the screws and cover off the final drive and forward chain gear. Your oil pump is there and so is a puck under the chain that ( crankcase seal).
Most guys have recently changed to an Oring  type chain and it's scrubbing the crankcase seal.
or possibly a beat shifter seal , but unlikely.
Other guys didn't tighten up a plug in the oil pump and it worked it's way back out.
We have seen some cracked lower cases due to a thrown chain.
Or a final drive seal failed.
Either of these things could be possible....Take it apart, take pictures and post them.
We need to see what you are talking about. If it  leaks when parked , it could be as simple as an oil pan gasket.
« Last Edit: August 03, 2014, 06:26:38 PM by rb550four »
Offline letutt
Re: huge oil leak!
« Reply #4 on: August 03, 2014, 08:56:35 PM »
I did just change to an O-Ring chain.  I'll post pictures in the morning.  Dang
Re: huge oil leak!
« Reply #5 on: August 03, 2014, 09:15:02 PM »
I thought orings were too big and punched holes in cases.
Offline letutt
Re: huge oil leak!
« Reply #6 on: August 04, 2014, 06:29:08 AM »
That would be the worst news for my bike ever.  I certainly hope that is not the case.
Offline wowbagger
  • Not much of an
Re: huge oil leak!
« Reply #7 on: August 04, 2014, 07:12:02 AM »
Pull the cover and post some photos so we can help identify the source of the leak better.
Re: huge oil leak!
« Reply #8 on: August 04, 2014, 07:50:51 AM »
The width of the oring chain on 550's is the issue.  There is a rubber plug just in front of the drive shaft, and the sides of the oring wear thru the case and this plug.
A spacer is needed under the drive sprocket to give oring chains the clearance needed if you're going to run them, or, once the damage is fixed, run a standard chain.
search CB550 oring chain damage
If this is NOT the source of your leak, it soon could be  :o
Offline goldarrow
Re: huge oil leak!
« Reply #9 on: August 04, 2014, 09:33:38 AM »
let's see some pictures of the leak?
CB550 K0
Offline letutt
Re: huge oil leak!
« Reply #10 on: August 11, 2014, 10:48:10 AM »
Here is the oil leak.  Where do I get another seal?  And how do I avoid this is the future?  I installed an o-ring chain.  Can I just space it out a bit?
Offline letutt
Re: huge oil leak!
« Reply #11 on: August 11, 2014, 10:48:58 AM »
Offline letutt
Re: huge oil leak!
« Reply #12 on: August 11, 2014, 10:52:08 AM »
Offline letutt
Re: huge oil leak!
« Reply #13 on: August 11, 2014, 10:55:55 AM »
And where do I get a new seal?
Offline wowbagger
  • Not much of an
Re: huge oil leak!
« Reply #14 on: August 11, 2014, 10:57:52 AM »
Partzilla.com is where I get most of my OEM parts. As for the spacing, I'm not sure if it's possible. You'd have to space both the front and rear sprockets to keep them inline. I'm sure a search here would turn up more than a few folks that ran into the same issue.
Re: huge oil leak!
« Reply #15 on: August 11, 2014, 12:38:38 PM »
it looks to have worn right through the rubber coated metal of the seal plug?ive seen a few rubbed but not right through,check around the oil pump while you have the cover off,run it with the cover off and be sure the oil pump isn't leaking aswell.
« Last Edit: August 11, 2014, 12:53:21 PM by dave500 »
Offline letutt
Re: huge oil leak!
« Reply #16 on: August 11, 2014, 01:18:04 PM »
Does anyone know the name of this seal?
Offline goldarrow
Re: huge oil leak!
« Reply #17 on: August 11, 2014, 01:31:09 PM »
don't quote me on this, but i think the fiche calls it OIL SEAL (34X8) 91207-374-000  $10 still available from Honda
CB550 K0
Offline letutt
Re: huge oil leak!
« Reply #18 on: August 11, 2014, 11:15:59 PM »
Awesome.  I'll check it out in the morning.  Thank you.
