Author Topic: 12-inch shocks…  (Read 1645 times)
AR-Guy
12-inch shocks…
« on: September 25, 2006, 02:32:49 PM »
I want to say thanks SteveD CB500F for compiling the The Thoughts of Hondaman.  ;D This post contains so much info Hondaman you should publish it!!!
Ok on to my real question: As per one of the post by Hondaman I would like to lower my bike by adding 12” shocks: what does the board thing is a fair price for new? And what if I can find them on e-bay might expect to pay?
Also any thoughts on different manufactures?
Thanks again,
Buck
Maybe this should be in the Tech forum, not really sure.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: 12-inch shocks…
« Reply #1 on: September 25, 2006, 02:35:42 PM »
Prob. a tech forum thing.
I got 11'' short shocks on my scoot from http://HTTP://WWW.CRC2ONLINECATALOG.COM
They were like 80 bucks or something...
AR-Guy
Re: 12-inch shocks…
« Reply #2 on: September 25, 2006, 02:38:20 PM »
Thanks for the info.
Can or how would I move this over to the tech?
At 11" do worry about the bike being too Low. Pipes scraping and such
Buck
Offline ProTeal55
  • Est1968.com
Re: 12-inch shocks…
« Reply #3 on: September 25, 2006, 02:47:55 PM »
I dont canyon-carve my bike or anything , but I can scrape the pipe when I want to scrape it.
My bike sits real low becasue of the 11'' shocks along with the switch toa 16'' rear wheel.
Low =  ;D in my opinion
AR-Guy
Re: 12-inch shocks…
« Reply #4 on: September 25, 2006, 02:51:24 PM »
When you lowered the rear did you do the same to the front by pushing the fork tube out the top of the trees?
Buck
Offline ProTeal55
  • Est1968.com
Re: 12-inch shocks…
« Reply #5 on: September 25, 2006, 08:58:27 PM »
Buck
Yup - about 2'' thru the top
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: 12-inch shocks…
« Reply #6 on: September 26, 2006, 04:36:50 AM »
Just loosen both the upper and lower triple tree bolts and push the shocks up.
On mine I cut 1 1/2" off of the front springs and pushed the forks up 1" for a total of 2 1/2" lower front and rear.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Roastem
Re: 12-inch shocks…
« Reply #7 on: September 26, 2006, 07:32:02 PM »
dude i just creamed my pants.... that is almost the identical look i was goin for with my 550.... now i know i will love my bike even more when i get it together.
Offline Einyodeler
Re: 12-inch shocks…
« Reply #8 on: September 26, 2006, 09:36:29 PM »
It`s easier to do if the front wheel is off, then you can 1 fork at a time, just make sure you support it good. After you loosen the bolts all you have to do is twist the fork while pushing up.
Offline ProTeal55
  • Est1968.com
Re: 12-inch shocks…
« Reply #9 on: September 26, 2006, 10:02:55 PM »
As said just loosen the triple-tree bolts and you are set.
I just rolled the bike forward a bit and clamped down on the front brake with the bolts
loose, which in turn put force on the triple-tree , which in turn pushed the fork tubes up thru
the trees. Just make sure when you do this that both sides are equal, as far as you have the same amount on both sides
sticking thru the top tree...
If you ride the thing and like the ride, you could always get a set of tubes made that exact length for a super clean look..
