Author Topic: f2 cylinder identification  (Read 1516 times)
Offline mad mike
« on: August 16, 2014, 10:31:10 AM »
help please, -  how do i identify f2 /f3 cylinders from k series cylinders, also ...... what mods. are reqd. to k series cylinders in order to run f2 cylinder head with them ???      thanks in advance.    mike
BELIEVE NONE OF WHAT YOU HEAR, AND ONLY HALF OF WHAT YOU SEE.
Offline Big Jay
    • CBRzone
Re: f2 cylinder identification
« Reply #1 on: August 16, 2014, 10:45:54 AM »
Mike;
Send me an e-mail, tech@aperaceparts.com and I will send you a photo of the bottom of an F2 block
Offline cbr954
« Reply #2 on: August 16, 2014, 01:44:49 PM »
Talk with Jay about doing the mod to the F2 cylinder head so you can use it on a K cylinder.  I am running a F2 head on my 970cc K cylinder motor.  I had Jay do the required sleeves in the head.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline Big Jay
    • CBRzone
« Reply #3 on: August 16, 2014, 01:58:32 PM »
You are right. I thought it was the block.
Offline mad mike
« Reply #4 on: August 18, 2014, 01:24:02 AM »
  confused ---  so is it a head mod or a cylinder mod???  in order to use f2 head with k series cylinders .   mike
Offline Yoshimatic
  • The Stable
« Reply #5 on: August 18, 2014, 03:49:41 AM »
Hi fellas, I wouldn't mind knowing also please. It's something different with the oil supply or oil drain off from the oil feed to the rockers but I'm not sure what the change is.
1969 GL175 twin
1970 CB750 K0
1971 CL350
1975 CB750F1
1977 CB750F2
1977 CB750A (original condition)
1977 CB750A (836 Cafe Racer)
1978 CB750F3
Offline cbr954
« Reply #6 on: August 18, 2014, 04:30:32 AM »
Sleeves need to be installed in the F2 cylinder head in order to use it on a K cylinder.  Sleeves are installed in 4 of the cylinder stud holes as they are open to the atmosphere on the F2 head.  The F2 doesn't use those four holes for oil return but on the K head they are used as oil return.  If you dont sleeve them then you have four open holes in the head that can allow water and dirt to enter into the crankcase down through the oil return drains in the K cylinder.  Oil can also migrate back up through and they you will have oil mist and leaks.  Jay did the work on my head and it is working perfect.
« Reply #7 on: August 18, 2014, 04:43:21 AM »
What he said ^^^
I put shrink tubing on my exposed studs plus blocked the jug portion of the hole - i.e. only the head part of the hole is exposed to elements.
Offline mad mike
« Reply #8 on: August 19, 2014, 01:15:47 AM »
got it now, - thanks for your help guys.
