Author Topic: Cracked overflow tube in float bowl. Fixable?  (Read 2779 times)
Offline Rufus2010
« on: August 27, 2014, 12:36:34 PM »
I have a 1974 CB550. In one of the float bowls the brass overflow tube is cracked. Can I fix this with JB Weld or some kind of gas resistant sealant, or replace the tube somehow?
Re: Cracked overflow tube in float bowl. Fixable?
« Reply #1 on: August 27, 2014, 12:38:24 PM »
I don't know with your ethanol fuels but ive simply used electrical shrink tube over them before,id solder up any next time I see them though.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: August 27, 2014, 12:45:52 PM »
I used JB weld on mine, but didn't keep the bike long enough to judge the long-term strength of the repair. But dueing the 3 months and about 4,000 miles of riding I had no leaks post repair.
If I were fixing it today I think I would solder the crack.
Offline Rufus2010
« Reply #3 on: August 27, 2014, 01:12:01 PM »
I never thought of soldering. I have a good soldering iron and solder. That should do it.
Offline lucky
« Reply #4 on: August 28, 2014, 06:54:09 AM »
Just clean the tube with sandpaper to shiny metal and solder the crack.
Do not fill the tube with solder! LOl..lol
Offline Chachi
« Reply #5 on: August 28, 2014, 09:18:20 AM »
Like Dave, I had one fixed with some type of shrink tubing before. The carb overflow tube leak baffled the hell out of me and my mechanic until we found the hairline crack in the post. He found it with a magnifying glass.
There's a member that offers float post repairs (micro laser welding):
http://forums.sohc4.net/index.php?topic=118804.0
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline kingrabbit
  • Half-Assed Wrench
« Reply #6 on: August 28, 2014, 07:25:08 PM »
I used a little dab o JB Weld on mine 3-4 years ago. No issues with that since. Super easy fix.
mine is also a 74 550K.
I wonder if it is cold weather that causes this? I am in E. Canada.
'74 CB 550K
'75 CB 750F
'73 XLH 1000
Donny
« Reply #7 on: August 29, 2014, 01:34:12 AM »
the ones Ive seen have been so hair line it almost was invisible,running almost the entire length of the tube perfectly straight,not sure how its caused like are they rolled and made too thin?or is it in how its entrapped in the bowl casting causing pressure?anyway I think its more common on the pd carbs?ive never seen early carbs with it?what do you think harisluv?
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #8 on: August 29, 2014, 05:00:11 AM »
Now I'm intrigued as to if this has happened to me, too.
--Evan
1975 CB750K "Rhonda"
« Reply #9 on: August 29, 2014, 06:03:56 AM »
It is not very hard to solder up a crack in the tube. It needs to be very clean.......very clean. Flux it up good and apply minimal heat. The solder will wick right into the crack.
