Author Topic: Loss of complete power, FIXED! THANKS CAL!  (Read 1181 times)
Offline Tews19
  • I am no
« on: August 31, 2014, 03:33:05 PM »
Less than 2 weeks ago I blew a fuse while riding. I swapped it out and today while riding I seemed to lose power while coming to a stop. I hit the start button and she fires up and home I get.
I swapped out the stock fuse box and simply put in a fuse. Today I attempted to fix this. See pic below. Now I have no power at all. I went to get another set up for the fuse and still no power. I pulled my gas tank and checked the connections there and all is connected. Any idea what to check?
« Last Edit: September 06, 2014, 03:25:22 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
Re: Loss of complete power on 71 750
« Reply #1 on: August 31, 2014, 03:34:45 PM »
Here are a few pics. First pic is the replacement. Second pic is how I ran it with a fuse in it. I put my battery on a charger and it's fully charged.
Offline Tews19
  • I am no
« Reply #2 on: August 31, 2014, 03:35:44 PM »
I am thinking it isn't my controls as they are brand new from Yamiya.
Offline Tews19
  • I am no
« Reply #3 on: August 31, 2014, 06:29:17 PM »
I opened up my headlight bucket and there is white corrosion on the bucket itself. Also on the wires.  My jerry riggin skills seems to have jacked it up. New harness will have to be ordered.
Do I go with the 200 genuine honda or can I get the 90 buck repop?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #4 on: August 31, 2014, 07:43:38 PM »
I just got a Z1parts.net harness and it is NICE!  (I offered $70 on ebay and they accepted).
Offline Tews19
  • I am no
« Reply #5 on: August 31, 2014, 08:38:27 PM »
Thanks Gregg. I will scoop that up.
« Reply #6 on: August 31, 2014, 10:32:44 PM »
What was wrong with the wires in the bucket Nick ? A complete harness change is a pretty big deal and there are a few differences through the years on them. Don't tear it all out till we get back from Holiday   ;)
Offline rb550four
« Reply #7 on: September 01, 2014, 07:45:56 AM »
I don't know  but, it looks like the blade to the fuse may have been corroded , power got through the fuse and heated up the blade, that's where I would start looking for trouble, red, then red and brown then blacks.
 Are your grounds from battery to frame and coil ground clean and in good condition ?
Q: does " Jacked it up" in this case mean that the wiring harness is "cooked",  "fried", or "crispy"?
Offline Tews19
  • I am no
« Reply #8 on: September 01, 2014, 07:47:54 AM »
Lots of black burn marks on the main harness RB. The positive battery screw was loose. I noticed this after I cut.the burnt red fuse connection off.
Offline Tews19
  • I am no
« Reply #9 on: September 05, 2014, 06:42:34 PM »
I received my new harness and ignition switch in the mail yesterday. Finally got around to replacing the crusty harness and still no power. Everything is wired correctly. Now to use the search feature on how and what to test next.
« Last Edit: September 05, 2014, 06:49:59 PM by Tews19 »
Offline Tews19
  • I am no
Re: Loss of complete power, FIXED! THANKS CAL!
« Reply #10 on: September 06, 2014, 03:27:07 PM »
Special thanks to Cal! He literally walked/talked me through the process of elimination!  The K1 has power and no more jerry riggin!
« Reply #11 on: September 06, 2014, 03:32:09 PM »
Good to hear Tews, Cals good people.... ;)
Offline Tews19
  • I am no
« Reply #12 on: September 06, 2014, 03:33:40 PM »
He is real good people! Not only did he talk me through it but taught me.how to check for incase of future issues. But I better get 43 years out of this harness!
« Reply #13 on: September 06, 2014, 03:46:50 PM »
I have a new harness too mate, i'll be tickled pink if it makes it another 43 years, that would make me 94 years old..... ;D :o
« Reply #14 on: September 06, 2014, 04:04:34 PM »
Aw, come now, Retro, as "others" have said, with the time it takes you to build a bike, it will only be in service for 6 months by the.  ;)
Having a laugh with you, not at you-
I'm right there with you mate.... ;D ;)
« Reply #15 on: September 06, 2014, 05:30:01 PM »
Late to the party....so what exactly was the issue?
Offline albertaboy
  • No way I'm a
« Reply #16 on: September 06, 2014, 06:13:30 PM »
+1. Or should I say +2, Cal's helped me out of a bind a couple times. :)
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
Offline Tews19
  • I am no
« Reply #17 on: September 07, 2014, 04:15:31 PM »
Lol I forgot to plug in the ignition?  Cal you promised!
