Author Topic: Fork spacers?? Cb750  (Read 1566 times)
Offline Dannodarko
« on: September 18, 2014, 11:43:46 AM »
Hi all!! So apparently my new progressive springs I ordered should have also come with spacers and some washers as well. I know the length of the spacer should be between 3/4 and an 1" but what about the diameter??? If I was home I'd just take out a set of calipers and measure the ID of the forks and get something just a little smaller than the 35mm...but I'm at work and a little impatient. Thanks all, you're the greatest!!! -Dan
Dan Faas
Gold Level Technician
Flemington Porsche
Re: Fork spacers?? Cb750
« Reply #1 on: September 18, 2014, 12:06:46 PM »
Dan Faas
Flemington Porsche
They use what amounts to PVC and fender washers. OR even standard washers. Just something so the springs don't dig into the PVC. But that's ot really a problem, the ends of the spings are machined to provide a flat surface. The washer just gives more perch.
So you can exeriment with spacer length by cutting your own.
Now to do some calculating: 35mm less wall thickness 3mx2 =29mm = 1.14" round down. USe 1" pvc and flat washers with an OD < 1 1/8".
Could be 1.25" PVC but that = 31.75mm which would be a tight fit. (Do they make 1 1/8PVC?)  and IIRC the spacers are sloppy in the tube.
PS: Seems they make both. Buy both they are cheap.
« Last Edit: September 18, 2014, 12:15:55 PM by MCRider »
Offline Dannodarko
« Reply #2 on: September 18, 2014, 12:41:17 PM »
Awesome!! Thanks for the quick reply!!!
Dan Faas
Flemington Porsche
